Old 03-19-2012, 03:07 PM   #1
Jammin#2's Avatar
Default CVD's????? True drive shaft design????
So I've been thinking about this for awhile now. Why hasn't anyone come up with a true drive shaft design with like a u joint on both sides of the shaft????
Id think it would get rid a few problems like drive cup wear, and would get rid of the chance of them popping out during a race.
your thoughts????
RELAX!!! It's a toy car race!
The TRACK @ Harbor Hobbies https://www.facebook.com/pages/The-Track-at-Harbor-Hobbies/125266694216753?sk=timeline
Team Associated RC8.2, RC8BE, SC10RS, TC5M, B5M, TC5R, B44.3
Jammin X1CR FTE, Corraly RDX Phi 09, 3Racing F1-09
Jammin#2 is offline   Reply With Quote
Old 03-19-2012, 04:13 PM   #2
LosiPRRACER's Avatar
because the shaft moves in and out of the cup during up and down travel.
and working on the car in a hurry would be a PIA as its just something else to take apart to get the car apart.
Hotbodies d815 / RCCONCEPT / Savox / Proline / Futaba 4px
LosiPRRACER is offline   Reply With Quote
Old 03-19-2012, 04:20 PM   #3
Jammin#2's Avatar
Good point! Lol
But i mean thinking now traxxas did it with the tmaxx, like Im thinking a modified more robust design that could take the punishment of 1/8 scale.
Old 03-19-2012, 04:26 PM   #4
motomatt's Avatar
The XO1
metal drive shafts with u-joints
motomatt is offline   Reply With Quote
Old 03-19-2012, 04:27 PM   #5
Trader Rating: 39 (100%+)
Originally Posted by Jammin#2 View Post
Good point! Lol
The traxxas plastic slider shafts are junk, especially in a racing situation. You would need to basically copy a full size car CV-joint, which would be way to intricate in small scale.
BrakeTurnAccelerate is offline   Reply With Quote
Old 03-19-2012, 04:31 PM   #6
yeah those slider shafts are crap
Old 03-19-2012, 04:35 PM   #7
Jammin#2's Avatar
O trust me those plastic slider drive shafts are crap dont get me wrong but you cant tell me u couldnt refine that design into something way better.
Old 03-19-2012, 07:06 PM   #8
Jaz240's Avatar
Trader Rating: 52 (100%+)
Chassis flex would kill em quickly, unless you figured a way to have a spring somewhere along the driveline front and rear
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-19-2012, 08:45 PM   #9
merdith6's Avatar
Default True
I've thought about it myself. I don't see why it couldn't be done, and last longer too, as long as it doesn't use set screws that can come out on the center outdrive area it would be awesome...
The current stuff wears out too fast and costs too much IMO...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 03-19-2012, 09:28 PM   #10
RCmayor's Avatar
Send a message via Yahoo to RCmayor
Not if you run a Serpent. lol
RCmayor is offline   Reply With Quote
Old 03-20-2012, 05:43 AM   #11
Morpheus847's Avatar
Trader Rating: 21 (100%+)
How about just remove the drive cups replace that with a splined shaft and put a slip yoke on the other end of the cvd/universal it would look just like the hub side of a 4wd joint just a little larger in diameter and splined on the inside. Same thing as the output on a auto tranny.
Tekno NB48.3, Werks B6, Byrons fuel
Mugen MBX6 tekno v4, Tekin RX8, Tekin T8 2650kv
TLR 22SCT 2.0 Brushless Hobbies 120a., Trinity DUO 10.5
SMC Batteries
Morpheus847 is offline   Reply With Quote
Old 03-20-2012, 03:53 PM   #12
madweazl's Avatar
Sliding shafts have been tried in fullsize racing for years and they just dont perform well. Simple is usually the best solution and for that, the CVA/CVD is tough to beat. Replacing a pin every month or so isnt what I'd call heavy maintenance; only takes a couple minutes and you're back in action.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 03-20-2012, 04:14 PM   #13
houston's Avatar
Trader Rating: 91 (100%+)
or the whole season on kyosho shafts
our designs are simple yet effective for a reason , you will figure it out '
there is always room for innovation though
it just has to be on the edge of inside/outside the box
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-21-2012, 11:43 AM   #14
how do you think these will hold up for 1/8th?
http://www.rcracer.co.nz/Forum/viewt...hp?f=12&t=3367
redbones is offline   Reply With Quote
Old 03-21-2012, 12:07 PM   #15
am
There are several reassons for why a normal car drivehsft couplung would not work very good for our use.
First is the extreame amaount of suspension travel. It is many many times of normal car.
Second, it would be alot more expensive, think what it would coast to change a driveshaft.
Third, it would be hell to wrench on our cars. You would need to find a secure way to attaceh the driveshaft to the diff, so it will not take anymore time than it does today.
forth, the friction in the CVD/CVA joint has some effekt to how the car is handling. With a normal cars driveshaft friction is alot less under power, and f. eks Losi is one of the cars that is loose on the rear end before the drivshafts wears in.
JConcepts
Kyosho MP9
KO PROPO
Top Elite distributor Norway
am is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46468 03-20-2017 08:56 PM
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
SERPENT MALAYSIA - News, Support & Discussion Centre xxafiquexx Malaysian R/C Racers 877 01-30-2014 07:36 AM
