Old 03-15-2012, 08:05 PM   #1
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Default shock setup
Wanted some comments when you guys build your shocks using oil and springs how do you setup for your track condition. I build so my chassis doesn't slap from a 2-3 foot drop. I also try to have equal compression and rebound rate between front and back. How do you build does your chassis slap from a two foot drop. I've been working on my shock setup a lot to me this is probably the biggest performance factor but wanted some input.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 03-15-2012, 08:06 PM   #2
LosiPRRACER's Avatar
two foot? most of my cars would jsut touch the ground(bumpy tracks)
Hotbodies d815 / RCCONCEPT / Savox / Proline / Futaba 4px
LosiPRRACER is offline   Reply With Quote
Old 03-15-2012, 09:30 PM   #3
bigjayjay1's Avatar
What don't understand your comment some people run really thick oils or hard springs cause they don't want any chassis slap to me it makes the car perform poor cause everything is tight their animate to make sure its happen. I just installed the CSI pistons version one blue some people are running 100 wt I tried but holy mother of mercy the rebound and compression was hard for my shock setup.
Old 03-15-2012, 09:41 PM   #4
Suspended
Trader Rating: 17 (95%+)
mine will slap the ground on a 3 foot drop, i like to run a soft set up on my truggy and buggy, (running a med. loomy large track) a hard set up will make it to twitchy for my driving style. i run really hard and seems to be best for me.
D-MAIN is offline   Reply With Quote
Old 03-16-2012, 12:44 AM   #5
bigjayjay1's Avatar
Yup that's me drive hard especially with me CRE mills some rides I see there suspension is super tight and they wonder why their traction rolling. Some kits I see their suspension is super light then they wonder why their kit constantly turns over when hitting the ruts. I'm just curious on people setup method I always setup were my chassis doesn't hit from a 2-3 drop what's your average height.
Old 03-16-2012, 04:26 AM   #6
honda237's Avatar
Trader Rating: 17 (100%+)
This is a great question, i was actually wondering the same thing.
I am running the old blue csi pistons, and i'm up to 1100 cst in the rear and its finally starting to feel like i have rear suspension on my D8, the front is fine with 70wt. I set my shocks up similar to what you do, but i'm just starting to race this rear, so i don't have much experience in that department.
honda237 is offline   Reply With Quote
Old 03-16-2012, 06:02 AM   #7
Maximo's Avatar
I thought a tight suspension prevents traction roll..?
http://www.thenitroshop.com/
Maximo is offline   Reply With Quote
Old 03-16-2012, 06:15 AM   #8
Pattojnr's Avatar
Trader Rating: 19 (100%+)
it prevents Chassis Roll. so when there is enough grip and the chassis cant roll anymore, then the outside of the tyres start to fold over, then it starts Tipping over. before you can back off, or catch it, its over she goes.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-16-2012, 08:21 AM   #9
Davidka's Avatar
Trader Rating: 75 (100%+)
If your car is not bottoming from a 3ft drop to the floor it is probably WAY too stiff everywhere but the biggest jump on the track. Remember, when the car lands from a jump, it is not falling straight down. The suspension's primary job is to handle bumps and traction. Try running softer (any pro's setup for your given chassis is a good starting point), I bet you won't have as much chassis slap as you think and it should handle better when it's on the ground.
My buggy's front end bottoms a little when I drop if from ~12-18" but it's no problem on the track and it handles correctly.
Old 03-16-2012, 08:28 AM   #10
Will i drop mine about 3 to 4 i think just to see how hard she hit. I normally try that then hit the track and see what she does. i never have any rebound in the front. and i run about 50% in the rear. if it hit just a little im good to go i think. I run a hard packed outside clay track in the summer. i like the chassie to roll just a little. If i get traction roll i change my tires from soft to med and that normally fixes it for me. I had never had i my car go over yet this way. Everytime i get it to not slap hard i seem to be to bouncy. i have found it seem to work best with the bigest piston i could find and the thickest oil for the shock with out making it bounce if it does that i drop oil by 5 %. so last year i had the 1.4 piston with 6 hole i drilled them to 1.5 and put 40front and 45 rear seem to be great.but this year im gonna try out the new compettion pistion. Now im lost at for the setup cause it feel just to soft on the bench. i learned this method from driving my t maxx in the races. I got one throphy race under my belt with the maxx doing it like this. I think shock and tires are the most important part of a setup.
Team Argus
Team Rw- Mods |www.rw-Rw mods.com|
Hotbodies D8T Argus .23 | tb - 1 pipe|
Hotbodies D812
Hotbodies ve8 Tekin 2050
imrob is offline   Reply With Quote
Old 03-16-2012, 04:07 PM   #11
bigjayjay1's Avatar
3' its hitting just added a range. I judge as if Im doing a ride height adjustment drop if i doesnt hit then I leave if its bottoms then I change.
I always feel other kits when at the track then watch their kits run its good feedback for me. I was watching JQ setup guide and I like how he does his setup very good information.
shock setup losi 2.0?? nitrozilla Nitro Off-Road 10 10-18-2010 07:32 PM
Need a good shock setup for slash diesel32x Electric Off-Road 15 02-22-2010 02:28 PM
Shock setup ??'s for 1/8 buggy schleprock3 Electric Off-Road 8 12-10-2004 09:06 AM
