Old 03-16-2012, 04:39 PM   #16
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by D-MAIN View Post
dont get these, they suck! they dont grab screw they just cut into it and pretty much drill it, not take screw out, i have these and are the worse item i ever bought
If you do not use the boring side of the bit provided get the results you have explained. You have to use their boring bit which prepares the hole properly for the extracting side to work. In addition, both sides of the bit need to be run in reverse. I noticed the boring bit on some of my other ones needs to be run forward.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 03-16-2012, 07:00 PM   #17
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Well you must have challenges I've used it many many times it works like a charm wouldn't recommend something that didn't maybe you need a show and tell but you bore in reverse flip and extract in reverse pretty simple maybe not pending on the user
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
