coming soon, a tutorial of sorts :) >
Old 03-13-2012, 10:42 AM
TheBurninator's Avatar
Default coming soon, a tutorial of sorts :)
I've seen pictures of it done, and am going to go ahead with it mylself, and that's converting a losi ten Scte to nitro. The parts needed are extremely cheap and I already have a beast of an engine to throw in. So I guess what I'm looking for is what sort of interest is there for such a tutorial?
TheBurninator is offline
Old 03-13-2012, 11:50 AM
TRF801XT's Avatar
how cheap are you talking?
price list breakdown??
TRF801XT is offline
Old 03-13-2012, 11:57 AM
Fuel tank - $7
Complete radio tray w all hardware - $5
Engine mounts and exhaust mount - $7
Center diff w brakes, splash guard, and linkage - $35
I already have the engine and servos but that's the expensive part I suppose.
Using a O.S. vzb v-spec turbo and airtronics and ace RC servos
Old 03-13-2012, 02:29 PM
madblu2's Avatar
Trader Rating: 33 (100%+)
I did it a lttle while back. Take a Losi 810 chassis and put the front and back suspension from the SCTE(with bumpers. You can also use the 810 gas tank, motor mounts, and center diff set-up. I drilled an additional hole to make the chassis accept the Losi 2.0B gas tank. You will have to use the 810 drive shafts. The side rails should directly bolt on. I tried it and had fun with it. Good luck with your build. You will get a kick out of it.
madblu2 is offline
Old 03-13-2012, 07:43 PM
Well according to losi specs and techs the ten-t nitro parts are a direct bolt-on
Old 03-14-2012, 11:10 AM
madblu2's Avatar
The 810, Ten-T and the SCTE are all built on the same platform.
madblu2 is offline
Old 03-14-2012, 11:28 AM
Only forseeable problem, there are no .21 mounts available for the 810 or ten-t so unless I can get custom ones, ill be getting an OS .18tz for it
Old 03-14-2012, 01:20 PM
madblu2's Avatar
Yeah i had to use the motor from the 810 on mine.
madblu2 is offline
Old 03-14-2012, 06:53 PM
I want something a tad more.... Rediculous lol
Old 03-17-2012, 01:32 AM
So far all parts are direct bolt on, all except .21 engine, will have to custom make an engine mount for it.
Old 03-17-2012, 02:04 AM
Juice1's Avatar
Trader Rating: 16 (100%+)
I did it awhile back...lots of fun! I used an os .18 and it had plenty of power.
http://m.youtube.com/watch?v=KqSDmzsZF94
Juice1 is offline
