Old 03-09-2012, 04:48 AM   #1
favo's Avatar
Default Which Servo Where
Which Servo would you fit to either Steering or Throttle.
Thanks for you help.
Savox Sc-1268SG
Dimensions(mm): 40.3x20.2x37.2
Weight(g): 62.0
Speed(@4.8V sec/60): .15
Torque(@4.8V oz-in): 160.0
Speed(@6.0V sec/60): .13
Torque(@6.0V oz-in): 208.3
Speed(@7.4V sec/60): .11
Torque(@7.4V oz-in): 347.2
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
Savox Sc-12687SG
Weight(g): 62.0
Speed(@4.8V sec/60): .13
Torque(@4.8V oz-in): 130.0
Speed(@6.0V sec/60): .11
Torque(@6.0V oz-in): 180.5
Speed(@7.4V sec/60): .09
Torque(@7.4V oz-in): 291.0
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
favo is offline   Reply With Quote
Old 03-09-2012, 05:07 AM   #2
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
68 on steering.
67 on throttle.
Rsickles is offline   Reply With Quote
Old 03-09-2012, 06:15 AM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
+1 if that's what you got. Personally I like 1268's on both steering and throttle.
Old 03-09-2012, 06:41 AM   #4
Jason-149's Avatar
Buggy 67 on both
Truggy 67 throttle 68 steering
TLR / Horizon Hobby / Spektrum / Upgrade R/C
Jason-149 is offline   Reply With Quote
Old 03-10-2012, 05:16 AM   #5
99problems's Avatar
I see you have the answer already. A good rule of thumb is the "higher torque servos are is usually used for steering".
Don't be a "CYBER BULLY" bring it to the TRACK!!
POINT and PULL!!
99problems is offline   Reply With Quote
Which servo to get? Syber Serulean Electric On-Road 28 11-17-2010 03:44 PM
Which servo should I put where? So*Cal AFDude Nitro Off-Road 6 10-19-2010 09:22 AM
which servo..IS THE SERVO IN CHARGE!!!!lets hear some feed back!!! comedyman809 Radio and Electronics 7 04-29-2009 11:53 AM
which servo's are the best for tc nitro neil Electric On-Road 49 12-02-2007 05:06 AM
