Traxxas slayer Question
i got two questions
#1 where is the battery on the truck its self
#2 the truck runs for about 1/2 its tank and dies no weird sounds just quits what could be wrong?
i have been running traxxas fuel
i cleaned out the air filter after every tank / run
idk can some one help me im new in nitro
i got two questions
I'm fairly new too. Slayer is almost identical to the Revo which is my first car.
Battery will be underneath the receiver and servo wiring. Remove the lid and look. Charge point will be underneath car. I assume its same as Revo and will have a charge port.
You should not be having to clean filter after every tank.
Make sure the truck battery is charged fully and your radio batteries are good.
After the 1/2 tank death, will it start back up?
i forgot to mention that it takes a while to start some time it wont even try to start
If after it is hot, that sounds like a sign of vapor lock. When it's stopped, use cleaner spray on the outside of the carb to cool it. Then try to start it again.
it runs great tho but i also know how to tune a nitro,lol
for the op, it could be so lean its not getting enough gas, or it could be so rich its choking itself till it dies. just gotta go off sound
