Stripped Screws?
+1, thats exactly what i do! i have also heated screw before putting it in but cant tighten to tight, it allows plastic to form around threads
Fortuantely I learned not to wrench on my cars at 3am when I come home from the pub. This saved me a lot of stripped threads
good to know
Wade, I have had success with the super glue method, it is best applied on the tip of a fine jewellers screwdriver and a thin coating applied to the stripped hole and let fully dry gives the best chance of a permanent fix. If in a hurry you can insert numerous objects onto said oversize hole including the fine tapered end of a cable tie, a cardboard sliver off a header card or even a sliver of match stick.
