Old 01-27-2012, 01:41 PM   #1
Default steering problems
I just put a new servo in my nitro truggy, and I ran it for the first time today, but I didn't run it long because the steering was acting funny. I could turn the truggy to the right and it would turn just fine, but when I turned it to the left and gave it some gas the steering would straighten up and the truggy wouldn't turn unless you let off the gas. What could be the problem with my truggy?
rc boy868 is offline   Reply With Quote
Old 01-27-2012, 03:47 PM   #2
Zao18's Avatar
First and most simple thing to check is your servo saver. It may have loosened off. Check your steering with the wheels off the ground. Now compare that with how far the steering moves when you lay your truggy on the ground. If they don't move as far, chances are the servo saver has backed off and it needs to be tightened.
If you tighten the servo saver and the steering is still poor, take apart the servo saver post and check the bearings. Also inspect your steering linkages to make sure they aren't binding or getting caught by something as they move.
Hotbodies D8T, Hitec 7955TG servos, "Clocked" Werks B5 w/ 2013 pipe, M2C 4-shoe clutch
Losi 810 buggy (converted Ten T), M2C Racing clutch, Hitec 7955TG servos, 125cc fuel tank
Spektrum DX3S w/ SR3300T receivers
Zao18 is offline   Reply With Quote
Old 01-27-2012, 04:10 PM   #3
alexrckid's Avatar
did ya CENTER the servo before installing the servo horn..?? did ya set the steering trim/subtrim's , on the radio, at their mid points, as well...??...these are a few of the things that can get ya.....also, make super sure that the servo horn that your using in spline compatable with the servo.......
2008/2009 northeast super series Production MT champion
8T-2.0, werks B5, 2013, hitec's.
gallimods hobbies and raceway, barn/wolcott.
living in north myrtle beach. race at badlands
alexrckid is offline   Reply With Quote
Steering problems on Tamiya TA05 and M03L nexxus Electric On-Road 16 01-06-2006 07:41 AM
