Old 01-27-2012, 03:57 AM   #1
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
Default 'Real Shocks'
With shocks being the hot topic of the new year has anyone seen these 'real shocks'?
www.realshocks.com
http://www.redrc.net/2012/01/mip-rea...ton-technology
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 01-27-2012, 04:30 AM   #2
Trader Rating: 68 (100%+)
I'm thinking that the Traxxas Revo platnium had something similar. We have the pistons and shims that go in the shocks at the store. They change the flow based on the amount of force. Since it was Traxxas, I never took it serious.
Dealer for Serpent, Intech, Agama, Pro Speed, JQ Products, Tekno
Alpha,Triton, Picco, Reds, Go, Arrow,Bullitt,Beta
Sponsor- Nemo Racing.
Greg B is offline   Reply With Quote
Old 01-27-2012, 04:39 AM   #3
I like the idea but think using the system reversed is probably the best way in offroad.
Schumacher K2, KF2, K1, KF | TeamC TM2 V1, TM4 | Durango DEX410 V3 | T-Rex 450SEV2,250SE | EMAX 250 | Gravity 250 | KC250
AmiSMB is offline   Reply With Quote
Old 01-27-2012, 04:51 AM   #4
Stubbs's Avatar
Trader Rating: 57 (100%+)
Interesting....definitely looks like 2012 is going to be a year of suspension innovations. About time too....
It would be interesting to know if this design provides progressive damping, based on shaft speed. At the very least it allows the user to control compression a bit better.
The discs appear to deflect, which controls the flow through the piston holes during compression. On rebound, the disc blocks off all of the holes, and the flats on the outside of the piston determine the rebound rate. Rebound rate is less critical, so that shouldn't be a big deal.
I know the cost is prohibitive, but I'd really love to see a true external bypass shock for RC cars. . That's where we would see significant advances in progressive damping.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 01-27-2012, 05:08 AM   #5
hakmazter's Avatar
It looks backwards to me unless there is a reason to slow down rebound?
I mass produced the first electric 1/8 scale buggy and truggy.
www.HopeWDM.org
I have thousands of dollars of caster racing inventory available.
Semi-Retired from this industry at this time.
hakmazter is offline   Reply With Quote
Old 01-27-2012, 06:25 AM   #6
This is how Penske racing shocks work for on road cars.
The reason they slow down the rebound is to help keep the tire planted. Its ideal for on road where you don't have to deal with bumps and jumps.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 01-27-2012, 06:30 AM   #7
morgoth's Avatar
Don't we want faster rebounding shock in RC offroad cars? This looks like the pistons has a dynamic compressionrate, but the rebound seems slow!
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 01-27-2012, 07:17 AM   #8
Logically speaking, would you want a fast dampening and slow rebound on a really blown out bumpy track? The fast dampening would "suck up" the bumps and the slow rebound would prevent the tires from falling deep into the valleys of the ruts.
However, I'm not a suspension expert...
my $.02
Nick Vasquez
Old 01-27-2012, 07:36 AM   #9
as long as whatever they come up with is priced good they will sell, but i think the future is in magnetically controlled shocks but it seems the cost of producing them keeps them from the market...
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 01-27-2012, 08:09 AM   #10
morgoth's Avatar
my $.02
If the shocks don't rebound fast enough, the chassis will bottom out.
Old 01-27-2012, 08:50 AM   #11
Precision1's Avatar
Trader Rating: 40 (100%+)
Yeah, generally you want the rebound to be faster than compression off road. Keeps the car reacting to the terrain and keeps it from "packing up" and staying too far into the travel. On road I think slower rebound is what you want w/ the smooth surfaces.
I actually have a set of the Traxxas stuff, super simple shim that covers 2 ports on compression, but allows all four to function on rebound. Or the opposite depending on how you put them in.
traxxas variable piston kit
Couldn't go wrong for $6, I put them in my Revo and it didn't really work that well at first. I opened up the rebound ports to 1.2mm (they were less than 1mm) and it works great! I have 40 wt in there now and need to bump it up to 50 wt, it's a little soft. Compression damping is noticeably slower than rebound. I am actually impressed w/ a $6 Traxxas part!
I just got a set of Fioroni dual pistons for the D8T. Speaking as a machinist they are nice looking parts, I can't wait to play w/ them!
Precision1 is offline   Reply With Quote
Old 01-27-2012, 03:11 PM   #12
Trader Rating: 14 (100%+)
watch a trophy truck go through the desert at mach...super fast rebound.
that keeps the tire in contact with the ground as much as possible which is what you need to get what you want out of a car/truck in "off road".
o.s. power is offline   Reply With Quote
Old 01-27-2012, 03:43 PM   #13
mblgjr's Avatar
Trader Rating: 86 (100%+)
MIP's been around a long time and usually, his stuff works very well.
It can be reversed for those wondering...
http://www.realshocks.com/Reversed.html
This is probably the most tuneable, but beautifully simple bypass type RC piston to be introduced to date.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 01-27-2012, 04:08 PM   #14
motomatt's Avatar
These RPM pistons have been around for a long time. (for T Maxx)
They offer "X" amount of compression damping and "Y" amount of rebound damping.
These new pistons from MIP offer the same thing.............BUT because they use a flexible disc, they are also shaft speed sensitive.
I can't wait til someone figures out how to gas pressurize our shocks.
motomatt is offline   Reply With Quote
Old 01-27-2012, 04:59 PM   #15
brainiac's Avatar
Does anyone have an ETA/Estimated cost on these things?
brainiac is offline   Reply With Quote
Real Race G2 Blacktiger355 Electric Off-Road 889 04-11-2017 07:40 PM
Post a pic of your real car civicruisin Chat Lounge 515 01-08-2012 09:40 AM
Team Associated B44 is for REAL tyreguy Electric Off-Road 3181 10-10-2010 10:58 PM
Real Race Simulator Rocket Electric On-Road 230 08-02-2003 02:14 PM
