Old 03-04-2012, 05:52 AM   #16
hookem34's Avatar
Trader Rating: 17 (100%+)
Very cool video.
http://www.youtube.com/watch?v=VlruG...caFAAAAAAAAGAA
Dan Culver
Companies I stand behind with my hard earned cash:
KyoshoClockwork Racing EnginesPT Racing OilsJet Lube ☆ Futaba ☆ Competition Heat ☆ Revolve RCNovarossiBuku PowerBones Motorsports
hookem34 is offline   Reply With Quote
Old 03-04-2012, 11:46 AM   #17
nice intro beat
RePeTe is offline   Reply With Quote
Old 03-05-2012, 09:18 PM   #18
kaptain crash's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to kaptain crash
Originally Posted by hookem34 View Post
Thanks hookem34.....man when they start their 1/8 scale REAL SHOCKS...think they will clean house in the ....after market....shock department. These guy's seem like the real deal...not the { we learned from the 1:1 shock guy's that worked for nascar bullcrap....} and still can't get right.
YEAH IM OLD...RUSTY AND SLOW,CRASH A LOT TOO. BUT WITH NITRO I HAVE A BLAST!
kaptain crash is offline   Reply With Quote
Old 03-05-2012, 11:18 PM   #19
Precision1's Avatar
Trader Rating: 40 (100%+)
Looks promising. The fact that they made a shock dyno to actually test the design says a lot. And the color coded shims are sweet!
Precision1 is offline   Reply With Quote
Old 03-07-2012, 07:59 AM   #20
Maybe we could start bugging them to step it up for the 1/8 scale buggys and truggys!
Old 03-08-2012, 01:27 PM   #21
Send a message via AIM to uDi_MP7.5
I've always wondered why this didn't exist in RC and how long it'd take for someone to make it - pretty cool.
For those asking why it's implemented in the way it is, I'll explain briefly:
In the rebound direction, the shaft speed is always physically limited by the spring rate and preload - the shaft can never return faster than the spring can rebound. Thus, the shaft speed can never get very high. Because of this, a ported damper is usually sufficient, or at least can be tuned to work *fairly* well with ease. As a sidenote, in this particular application, having shimmed damping in both directions would also require a much more complex piston - probably why it's not there.
In the compression direction, things are very different. The shaft speeds, while not completely unlimited, can reach much higher rates - because you are only limited by how fast you can hit bumps, and square edged hits can result in quite high shaft speeds. At these shaft speeds, the port area (which on a conventional RC shock is the same as what is available in the rebound direction) is going to be overwhelmed and thus damping spikes will occur.
The benefit of shimmed compression is that as you hit bumps and shaft speeds increase, more flow area can open up, to stop the damping curve rising progressively and causing spikes. It also means that you can run more low-speed compression damping (i.e. a smaller initial port area - which in this particular implementation is also your rebound damping port area) - which is useful for support under cornering loads and jump takeoffs / landings - without sacrificing performance in the bumps / rough sections like you would do if you didn't have that extra port area that opened at higher shaft speeds.
uDi_MP7.5 is offline   Reply With Quote
Real Race G2 Blacktiger355 Electric Off-Road 889 04-11-2017 07:40 PM
Post a pic of your real car civicruisin Chat Lounge 515 01-08-2012 09:40 AM
Team Associated B44 is for REAL tyreguy Electric Off-Road 3181 10-10-2010 10:58 PM
Real Race Simulator Rocket Electric On-Road 230 08-02-2003 02:14 PM
