Old 01-17-2012, 04:42 AM   #1
Default Make an electric vehicle
Hello. I have a DURATRAX Car Car Model AXSIS. I want to turn it into electricity. If there is a need to change body composition. If there have been examples of work done. Sorry about the English
ehau is offline   Reply With Quote
Old 01-17-2012, 07:15 AM   #2
hakmazter's Avatar
Why would you not just buy a real electric 1/8 buggy and be done with it?
It isn't like Duratrax is anything great to start with?
By the time you get done messing around, you probably could have just got a vehicle.
If you are outside the US, look for a Caster Racing sport roller or a Hobbytech sport roller for example.
I mass produced the first electric 1/8 scale buggy and truggy.
www.HopeWDM.org
I have thousands of dollars of caster racing inventory available.
Semi-Retired from this industry at this time.
hakmazter is offline   Reply With Quote
Old 01-17-2012, 10:18 AM   #3
It's not that simple you're married. What do the my partner does not like my hobbies. No technical diving. And airplanes. And riding a dirt bike. I just have the car recently and I get to him he has a problem starting handle. How this car is bad DURATRAX. and if equal to arrange with him. has the drive system. whether this axis bearing pressure should get this. A THUNDER TIGER engine
Old 01-17-2012, 10:37 AM   #4
Cummins Driver's Avatar
Trader Rating: 18 (100%+)
Are you wanting to use the thunder tiger parts in the duratrax engine? If so, it wont work. You can put the thunder tiger engine in the axis buggy though.
Or if you want to make it electric, you can make a motor mount out of aluminum angle. Trim it and drill holes to bolt it to the frame, and bolt a motor to it. Then install the motor/esc/battery tray and it should work fine.
Too many R/C's to run at once...
Cummins Driver is offline   Reply With Quote
Old 01-17-2012, 11:31 AM   #5
you'll probably end up spending more money, time, and frustrated from where you are starting. I suggest getting a more purpose built platform...
And you'll get better replies from the electric off-road forums. They should be able to help you with your one-off project.
redbones is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Electric vs nitro discussion TTKDracing Nitro Off-Road 115 04-04-2011 11:40 AM
Winter 08/09 RHR Racing: ELECTRIC OFF-ROAD RACING ANYONE? rustlerboi1052 Minnesota and North/South Dakota Racing 136 03-04-2009 10:46 AM
Your Opinions Please! Re: Pit Stops, 8th Scale Buggy, Truggy, Nitro, Electric mfanke19 Wisconsin & Illinois Racing 139 03-28-2008 07:43 PM
