Old 01-06-2012, 08:25 PM   #1
Default Spur Gear
My brand new buggy! I was breaking in the engine and then I started to drive it in circle and my spur gear teeth got torn up! I order my new gear any idea what I need to do so it won't happen again thanks! Losi 810 by the way
okla_elite_RC is offline   Reply With Quote
Old 01-07-2012, 02:14 AM   #2
morgoth's Avatar
Mesh too tight/too lose? A spur shouldn't break while breaking in :/ My spurs last a whole season and it gets a lot more abuse during racing than during the break in process.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 01-07-2012, 11:35 AM   #3
Zao18's Avatar
http://www.losi.com/Products/Feature...rodId=LOSB3570 is the replacement spur gear for the 810 and Ten T. Keep 3 or 4 in your toolbox, I am dead serious. They are only plastic, and pretty soft plastic too IMO. The gear stripped because your gear mesh was set incorrectly. It was either too loose or too tight. Both will cause a stripped spur gear. For me, I have found mine strip because of a loosened mesh that occurs during use of the vehicle. The mesh seems to back off over time from engine vibration and impact of landings on the track. I reset my mesh every time before I use my car for the day, and I still occasionally get a stripped spur gear from a gradual loosening of the mesh. You'll know right away when it happens too. Your car will barely move with throttle and you can hear a sort of high-pitched whining sound. Sometimes if you are lucky, you'll hear the whining sound before the mesh totally goes off and your spur gear is destroyed.
So to sum it all up: check your mesh EVERY TIME before you use the car, and keep a bare minimum of 3 spur gears in your toolkit. They're dirt cheap, and it ruins your day at the track if you have none left.
@ Morgoth: Are your spur gears metal? There's a huge difference between the cheap plastic spur gear that comes on the Ten T or 810 buggy, and the metal spur gear that came with my D8T kit.
Hotbodies D8T, Hitec 7955TG servos, "Clocked" Werks B5 w/ 2013 pipe, M2C 4-shoe clutch
Losi 810 buggy (converted Ten T), M2C Racing clutch, Hitec 7955TG servos, 125cc fuel tank
Spektrum DX3S w/ SR3300T receivers
Zao18 is offline   Reply With Quote
Old 01-07-2012, 10:12 PM   #4
Frank L's Avatar
Trader Rating: 148 (100%+)
Replace it with a metal gear and set the mesh correctly so theres a little more than you want with an electric 1/10.
Old 01-08-2012, 01:44 AM   #5
morgoth's Avatar
Yea, mine is steel. I wouldn't use a plastic spur in a 1/8 buggy. There's too much flex around the spur gear and when the clutch gets hot, the plastic start to soften up.
And also Frank L's instructions, they are spot on ;-)
Metal vs. Plastic Spur Gear in Electric Losi 8ight RGraves Electric Off-Road 19 09-16-2012 06:18 PM
Pinion/Spur Gear Mesh with paper Question Makoglm Rookie Zone 20 02-16-2010 12:33 PM
Spur gear on rustler vxl salabarria Electric Off-Road 15 04-17-2009 12:32 PM
Spur Gear wobble...??? RCRat Electric Off-Road 17 09-01-2008 04:55 PM
