Old 01-04-2012, 02:34 AM   #1
Default Grease Spray Lithium Base
I got a can of Grease Spray Lithium Base lying around, my question is
1.Can i use it for my bearings instead of paste type grease?
2.Can i use it as an after run oil replacement for my nitro engine since its a lubricant?
asanthadenz is offline   Reply With Quote
Old 01-04-2012, 04:07 AM   #2
NDHotbodies's Avatar
I started to use it on my bearings this year and seemed to work. But I would'nt use it for after run oil..
self sponsored, flat broke, highly sought after test dummy for Hotbodies..
I don't spell wrong, I just use shorthand sum time..
NDHotbodies is offline   Reply With Quote
Old 01-04-2012, 09:18 AM   #3
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
I woulnt use on bearing maybe CV couplers for the axles use Sin bearing lub awesome stuff makes them super smooth rotation best product Ive found.
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 01-04-2012, 09:51 AM   #4
oghobavo's Avatar
Default White Lithum Grease Spray
If you talking about "white'' lithium grease spray(got my can from home depot)then yes, they are good for bearings, ring/pinion, etc. As ND said, I wouldnt use it on an engine or carb. I pop all the seals off the bearings and dump them in a jar of NAPTHA and let them soak for about 20min(occasionally swooshing around jar), next I dump them out and let them dry for 10min(NAPTHA air drys super fast), then spray a paper cup half full of white lithium spray, put all the bearings in the cup to soak for about 10min, dump em out, put the seals back on, and there just as good as new. If bearing is still gritty after this, means its bad and just throw it out. Never had any bearing failures since doing it this way, hope this helps man.
2013 Xray XB9 & Kyosho TKI3
OS Speed .19 & .21 XZB/OS 2090
Airtronics M11X|Hitec ST/TH 7955's|ProTek Lipo's
Bones Brew 30/8|Competition Heat|Buku Clutch|PTRC Oils
oghobavo is offline   Reply With Quote
