Old 12-31-2011, 09:15 AM   #1
Questions?? Tuning firestorm 10t
Hello, I am new to forum and nitro cars. I bought a firestorm about 3 weeks ago now. I have run it in but when it comes to the tuning side of things no matter what slight changes I make it just does hit full speed but it nearly dies and I have to slow it down a bit. I have tried adjusting the high speed but it won't have it, I getting stuck now so any help would be great.
I have made a few mods, new few aluminium body parts and suspension bits, new wheels and tyers. Aluminium exhaust, and custom body also moved battery box to the front to stop it pulling wheelies lol, But this is all pointless unless its running right.
Thanks Greg
Gregwilliams111 is offline   Reply With Quote
Old 12-31-2011, 08:02 PM   #2
Zao18's Avatar
Originally Posted by Gregwilliams111 View Post
...it just does hit full speed but it nearly dies and I have to slow it down a bit.
From your description, that sounds like a lean bog. Basically, your high speed needle (HSN) on the carb is set too lean, so when you are approaching top speed, the engine is starving for fuel and starts to hesitate. If this is the case, you are dangerously close to cooking your engine. Richen your HSN needle at least 2 hours (think of the needle screw as a clock, and move it back 2 hours). You should see this hesitation disappear. Also, since the HSN affects total flow of fuel through the carb, once you richen the HSN you may find that take-off from idle is a bit sluggish. If this is the case, then you will need to lean out the low-speed needle (LSN) an hour or 2.
Start with richening the HSN first though and see what happens.
Hotbodies D8T, Hitec 7955TG servos, "Clocked" Werks B5 w/ 2013 pipe, M2C 4-shoe clutch
Losi 810 buggy (converted Ten T), M2C Racing clutch, Hitec 7955TG servos, 125cc fuel tank
Spektrum DX3S w/ SR3300T receivers
Zao18 is offline   Reply With Quote
Old 01-02-2012, 02:08 PM   #3
Thanks for the reply, I have tried to richen the mixture but
Still no luck. Even when the hsn is at the fresh out the box position it still bogs at full throttle. Should I be able to go from standstill to full throttle and not have any problems or does the speed have to build up. I have a video of what happens when I do this which I will upload at some point, on iPhone at the mo so can't. I took the engine apart today and had a look but everything looks new still so hopefully no damage has been done.
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
HPI Firestorm 10t Package X2 Fred Perkins R/C Items: For Sale/Trade 9 10-11-2011 05:27 AM
Punggol Off-road Track. Superb Singapore R/C Racers 9453 02-24-2010 09:26 PM
AE GT2 and HPI Firestorm 10T Opinions imprtcrx Nitro Off-Road 14 09-20-2007 04:18 PM
