Old 12-30-2011, 09:43 AM   #16
gameholic2's Avatar
that's why throttle return springs or elastics are usefull you don't have to keep pressure with the servo!
i leave a little bit of play so the servo DOESN'T hum.
gameholic2 is offline   Reply With Quote
Old 12-30-2011, 10:06 AM   #17
morgoth's Avatar
Now you're stressing the servo more while driving because it's has to pull the rubberband.
Anyway, the buzz that you while the servo is at the idle position is normal. You can hear the difference between a stressed servo and a servo that's slightly pushing on the spring. Servo's in a plane get a lot more stress than they do in our cars and they also survive.
Just make sure that your servo is in neutral position when the failsafe kicks in if you don't want a dead servo by accident.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-30-2011, 10:28 AM   #18
gameholic2's Avatar
The whole idea of the rubber band is to have a fail save even if the rx battery disconects the fact that it closes my carb shut is just a positive bi product.
I seriously doubt two thin elastics will stress a servo anymore than having pressure applied all the time keeping the carb shut...
Old 12-30-2011, 12:21 PM   #19
Nitro Tiger's Avatar
Originally Posted by Mark _australia View Post
Well does somebody want to post a tutorial on how to set endpoints and setup linkages so servo's aren't making noise and clicking away when not being used?
Bacically adjust your end points so there not binding, adjust throttle so there's about 1mm gap (called dead band) before it starts to pull on your carby from idle and set open to just past you restrictor, same with steering, work out where maximum travel from left to right then set your end points to stop the servo just before max travel so your not loading up the servo.
Wade Lazich- NSW 1/8 IC State Delegate.
Thankyou for your support- Werks Racing USA/ Pro Rc Supplies/ Aka Aust./ Ryper Hobbies
LRD- Australian distributor of Werks Race Blend 30% fuel. Dedicated solely to the supply of racing products for 1/8 scale nitro Rc. -lazrd.com.au-
Nitro Tiger is offline   Reply With Quote
Old 12-30-2011, 12:36 PM   #20
+ YouTube Video
redbones is offline   Reply With Quote
Old 12-30-2011, 12:47 PM   #21
morgoth's Avatar
That's my point.
Old 12-30-2011, 05:19 PM   #22
Thanks for all the throttle stuff fellas I can see how I did it is right - just thru logic and what the manual says.
Now what about steering somebody was talking about? I just adjust it so I get max turning
Mark _australia is offline   Reply With Quote
HPI Cup Racer 1M Dan Electric On-Road 3382 01-20-2017 05:19 AM
Alor Setar Rc racer nazaboy Malaysian R/C Racers 4787 10-02-2015 09:04 AM
Tamiya DB-01 Durga. The next budget racer? streetracer745 Electric Off-Road 923 11-25-2014 10:16 PM
TRACK STAR RACER SERVICES NOW OPEN (SoCal) Racecrafter Nitro Off-Road 1443 08-13-2012 12:41 PM
