few ??? about HB D8T
Just picked up a hb d8t what are some good setups to start with.
Is there anything that needs to be done for steering (have been running z01-t for the last year) so if any body can help. thanks mike |
the truggy is very solid right outta the box....but u will need alum rear hubs forsure alum servo horn and really u can dial it in from there....i am running a very aggressive setup on my truggy, but i am running 20-20-10 on the diffs and 35-32.5wt w/1.3 pistons on shocks...white/orange springs
but check out tytessman.com for some hb tricks and setups as well.... goodluck :sweat: |
I didn't like the aluminum rear hubs. But like said get the aluminum steering horn. I liked the Josh Alton designer setup on the hb website. I just made small changes from there. I also didn't like the orange rear springs. I used the white front and blue rears with 1.2mm pistons and 35wt
5/7/3 1.3 6 hole shock pistons 500wt in front and 450-400wt in rear
Originally Posted by metalbart
(Post 10088501)
Is there anything that needs to be done for steering (have been running z01-t for the last year) so if any body can help. thanks mike Box Stock set up to me is so easy to drive, with the exception of the Aluminum servo horn and Mugen captured outer hinge pins. |
Thanks for the help so far started reading the hb thread last night hopefully I'll get to the track this weekend and start dialing it in.
thanks mike |
