Old 12-26-2011, 09:09 PM   #1
Default new to nitro and need some help
Ok this is a really dumb question but here it goes. I was running last weekend indoor clay and my car seem to not be running like it was the weekend before. Was going through it tonight and found I didn't have a good seal from my header gasket to my pipe. When I adjust the pipe mount up front and pushed the pipe back figured I jared it from last practice do I made an adjust moved the pipe back to get a hood seal. Figured that was the loss of power source. After doing this I noticed the header had a cocked seal to the engine...really I'm not this dumb but what am I doing wrong.
Josh
smash79 is offline   Reply With Quote
Old 12-26-2011, 09:16 PM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
what you are doing wrong is trying to force everything to fit with the stuff you have. Take off the pipe hanger completely and make sure your header and pipe are straight and level and all sealed good with your engine. Then you can connect the pipe hanger. There are situations where you will have to cut or bend the pipe hanger or even the header ( bend, dont cut) to make everything line up properly and seal good. You may also need to spin your pipe hanger mount, which is very simple just by loosening the screw on the bottom of the chassis. Having everything line up and seal good is more important than having it look nice.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 12-26-2011, 09:16 PM   #3
Sorry for the word predict but you guys get the point
Old 12-26-2011, 09:22 PM   #4
Cool...what's the best method you found on bending a header? I don't want to monkey it up too bad...looks are not important I noticed a substantial performance loss end a hard time at idle. Is it common to bend a header from a good enough hit? Thanks for the quick response..also I notice I'm just messing the springs up pulling off with needle nose..us there a better method ?
Old 12-26-2011, 09:38 PM   #5
Yeah after looking at it closer my header looks bent. It's hooking in too far to the right where it meets the pipe. Don't know how I manged that or maybe an overlook when I bought it but I'm going to purchase a new one tomorrow. Any suggestion on a good one?
Old 12-26-2011, 09:41 PM   #6
heat gun or small propane torch to heat it up works well, but i doubt you need to bend your header to make it fit right, adjust pipe mount (not at motor, the other end) and get it close and make sure you have a good gasket at motor and header/pipe and you should be good to go. what motor and pipe? i know some are not good to run together, the wrong pipe with a engine can either make pipe run hot (drying up gaskets) or the engine run hot. i have found that the 053 and the 086 will get hot when running on a long stroke engine, atleast has been my experiance. try to straighten things out first before you go bending headers, may save you time and money
D8TRACER is offline   Reply With Quote
Old 12-26-2011, 09:50 PM   #7
I tried adjusting by pipe mount in front. Completely loosened and tried a few different positions and nothing seemed to line up. Engine is a ninja jx21 bo1a and pipe is a jammin Jp1 not sure on brand of header
Old 12-26-2011, 09:52 PM   #8
As far as header to pipe gasket is pretty well hit. Looks like it was getting pinched and is sliced on engine side of the diameter
Old 12-26-2011, 09:53 PM   #9
that engine/pipe combo should be good, does it seem the pipe needs to go out or in towards the fuel tank more?
Old 12-26-2011, 10:00 PM   #10
ok, sounds like your header may be bent to far then right?..... i have a jp-2 header if you want to give it a try since you dont know what header you have, throw me a pm and will send it to you free of charge and see if thats works better for you.
Old 12-26-2011, 10:04 PM   #11
Yup exactly it would have to surpasses fuel tank for a proper seal...thanks man pm you now
Old 12-26-2011, 10:10 PM   #12
i know your frustration, we have all been there at one point! just give me your mailing info and will be sent tomorrow for you! ill include a new gasket for you just incase!
Old 12-26-2011, 10:13 PM   #13
Sent you a pm. Forgot to add my name..Haha ...josh mcdougal ...thanks a million dude !
Old 12-26-2011, 10:16 PM   #14
dint get a PM. make sure you click on send PM to D8TRACER., just click on my user name and then click on send private message to..bla..bla.
Old 12-26-2011, 10:24 PM   #15
So does this mean jetting is going to be necessary again? Guessing so...
I am pretty new to nitro and need new engine which one should i get? savannahmick Offroad Nitro Engine Forum 23 08-04-2011 02:16 PM
new to r/c need some help smithjeeps Nitro Off-Road 10 09-10-2008 07:26 AM
NEED SOME HELP....AM I WRONG? Fred Perkins Buyer/Seller dispute and Feedback discussion forum 60 01-25-2008 04:53 PM
