Old 12-26-2011, 02:04 PM   #1
Nitro blast's Avatar
Questions?? Stopping the Beast
What works for you experienced racers?
Cleaning the break pads without dismanteling the diff, or cutting some groves on the calipers. I'm having issues with breaking.
Your expertice is appreciated.
Nitro blast is offline   Reply With Quote
Old 12-26-2011, 03:37 PM   #2
PAGIE #536's Avatar
Post
could be your epa setting is not correct on your radio or you need to screw in more brake on the adjusting rods for the front and rear on you car, hope this helps.
-Simon Page-
AKA Australia/Ryper Hobbies
https://www.flickr.com/photos/simonpagephotography/
www.facebook.com/SimonPagePhotography
PAGIE #536 is offline   Reply With Quote
Old 12-26-2011, 03:38 PM   #3
Personally, I think it's important to take out the center diff and check everything to make sure there's no strange wear on anything. You can get a good look at everything this way, too. I would try to clean the pads with brake cleaner or something similar, and the same for the discs. If you can't get them cleaned effectively, just pick some new ones up and throw em on.
R. Zwart is offline   Reply With Quote
Old 12-26-2011, 03:40 PM   #4
+1 to the epa and adjustment rods, hope you can get it all figured out
Old 12-27-2011, 08:15 PM   #5
Default EPA
Thanks for rattleing my head. Sometimes it takes some one to lead you in the right direction .
Old 12-28-2011, 07:29 AM   #6
Trader Rating: 17 (100%+)
Removing and sanding on a flat surface works the best. Brake clean just cleans the surface, ie. oil, dirt or solvents. When you sand them you actually resurface the pad "roughin it up" if you will, giving the pads something to grab a hold of. As for "picking up a new set" this can be a bit expensive, some brands are upwards of $25.00 a pair.
reeltech is offline   Reply With Quote
Old 12-29-2011, 04:17 AM   #7
NEMESIS44's Avatar
Send a message via AIM to NEMESIS44
This is what I do and I always have good brakes.
Losi 8ight 2.0,Werks B6, Spektrum, Savox HVs, AKA
Loving me some FRC!
NEMESIS44 is offline   Reply With Quote
Old 12-29-2011, 07:19 PM   #8
NEMESIS44's Avatar
You just have to get in there and work on your car, do constant maintenance check-ups, regular baths. You'll learn every nut, bolt, and pin in it and you won't be scared of any section of your car anymore. That way you can make quick repairs and use tuning options that alot of drivers don't use at the track because they can't get it done in time to make the race. Hope this helps.
Loving me some FRC!
Outback RC Raceway BobWoodhouse Wisconsin & Illinois Racing 4732 12-29-2010 05:46 PM
NOOB 1/10 EP Offroad Buggy Series - ANNOUNCEMENTS thread BloodClod Singapore R/C Racers 423 12-27-2010 09:10 AM
EXTREME RC MODIFICATION - Findings and Discussions mop_iko Nitro On-Road 126 08-20-2004 02:12 PM
