Old 12-15-2011, 12:12 PM   #16
Originally Posted by JoeGuam View Post
If you do not have a pin replacement tool this will be a great addition to any tool box. It works as intended, and anyone buying it will not be disappointed.
Hey Joe,
Whats the yen rate right now? If its not too far off, I may have to send you some cash to pick me one up. I finally got my TMO in and I need to tear everything down and rebuild. Let me now.
Adrian
Revooooooo is offline   Reply With Quote
Old 12-15-2011, 02:50 PM   #17
JoeGuam's Avatar
Originally Posted by Revooooooo View Post
Hey Joe,
Adrian
Its 78 yen to the dollar for the pin replacement tool = 3,528円 so about $45. Keep in touch
MBX6T AB MOD OS.25; AB MOD Picco 28
FLM EXT LCG SAVAGE AB & ERCM Picco .28
HPI BAJA OBR 30.5 AND OBR 57CC TWIN
www.abmods.com
JoeGuam is offline   Reply With Quote
Old 12-15-2011, 02:52 PM   #18
JoeGuam's Avatar
Originally Posted by bigjayjay1 View Post
Seems you need to put the bottom portion in a vice then your able to turn adding pressure on the shaft IE pin >True?
You can hold the tool with your hand or use a wrench for leverage.
www.abmods.com
Old 01-28-2012, 04:13 AM   #19
voodoopapa's Avatar
Any feedback on the mugen driveshaft pin removal tool?
voodoopapa is offline   Reply With Quote
Old 01-28-2012, 04:59 AM   #20
morgoth's Avatar
Yea I'd like to know that too. It looks really good and it's a lot cheaper than the Hudy one. I usually replace my pins with a benchvise, but that's not as easy as with the tool
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 01-28-2012, 06:46 AM   #21
MadRussian's Avatar
Yes sorry I missed this question.
We have sold quite a few, and everybody has said they work exactly as they should
MadRussian is offline   Reply With Quote
Old 01-28-2012, 07:04 AM   #22
Shane Racer's Avatar
I have used mine a few times so far and it works awesome. Easier to use than the Hudy and it's cheaper.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 06-05-2012, 09:49 AM   #23
Trader Rating: 55 (97%+)
Where can I get the replacement tool w/out paying $12 shipping on top of the exorbitant pricing @ mugen racing?
Or where can I get the Hudy tool?
shagnat is offline   Reply With Quote
Old 06-05-2012, 10:19 AM   #24
MadRussian's Avatar
Our prices are usually lower than amain's across the board, I would hardly call them exorbitant.
As far as shipping, http://racemugen.com/catalog/shipping.php
The shipping charge is sometimes calculated higher than it should for UPS (on small light items)
We only charge the correct amount, ask any of our clients we are 100% honest and straight up. You wont find an unhappy client of ours.
Shipping by itself via UPS on that tool should be around $7-8, which is all you would be charged, or if you paid by Paypal, the difference would be refunded.
Old 06-05-2012, 10:42 AM   #25
Maxxed-out's Avatar
Trader Rating: 15 (100%+)
The tool works but the shaft (B0541D) used to press the worn pin out will break easily. I have broken 2. I use heat and still broke them. The replacement is only $10 so I would recommend having at least 1 on hand. I think the reason it breaks is the pins are worn on one side and when you screw in, the pressing pin doesn't meet up with the drive pin flush. When you screw down, the pressing pin rotates and falls of the edge of the worn pin and causes it to be in a bind and break, or it breaks from putting pressure only on one side of the pressing pin. You just have to be careful or change out your pins before they get too much wear. You can also cut the pins off flush with the drive shaft with a dremel then press it out so that you make good contact with both the pressing pin and worn drive pin.
Hope this makes sense...
Billy Carpenter - Flowood RC
Thanks: JConcepts - CRP, Competition Heat & Competition Suspensions Inc - Fusion X Engines
HotBodies D812 - Tekno EB48.2 - Mugen MBX6T
Maxxed-out is offline   Reply With Quote
Old 06-05-2012, 10:59 AM   #26
cavg's Avatar
Totally agree with the shaft to press out the worn pin breaking easily. Mine started breaking on the first pin i tried to remove.
Nice tip on dremeling off the worn part, will try that when and if i decide to get a replacement shaft.
cavg is offline   Reply With Quote
Old 06-05-2012, 12:51 PM   #27
CanyonCarverR1's Avatar
Where did you guys buy that broken part(B0541D)? I can't seem to find one in stock anywhere.
CanyonCarverR1 is offline   Reply With Quote
Old 06-05-2012, 01:46 PM   #28
MadRussian's Avatar
We have them, they just haven't been added to our online store yet.
They should be in shortly.
Edit : just added it myself
http://racemugen.com/catalog/product...oducts_id=1072
Old 06-05-2012, 04:10 PM   #29
I just tried to order 2 from you but your system says they are backordered.
So, do you have them, or are they backordered?
Edit: just tried to order 1, it wasn't backordered so I assume you have just 1. But I'm sorry, $14.89 for shipping on a tiny $9 tool is a bit steep. Maybe when I need to order more items I'll try again. In the mean time, have you considered looking into cheaper shipping? A small flat-rate box through USPS is under $6.
Old 06-05-2012, 08:56 PM   #30
MadRussian's Avatar
Our inventory is live, yes we have only one left, as far as shipping prices, please look at post #24 above
We don't usually use the USPS because of many lost packages and poor tracking. If you want USPS still, select store pickup as an option, and we will ship it USPS for $5. We try to please
MUGEN SEIKI MRX5 John Doucakis Nitro On-Road 2924 02-17-2017 08:06 AM
NEW D8 Atsushi Hara Edition* Atrackstar101 Nitro Off-Road 5998 05-13-2016 12:24 AM
Mugen MBX6 teeforb Nitro Off-Road 18539 03-20-2016 02:59 PM
cv pin removal tool mrbusta Nitro Off-Road 38 09-06-2009 05:11 PM
