(CSI) COMPETITION SUSPENSION INC. >
Old 03-24-2014, 06:27 AM
  #1921
morgoth's Avatar
Originally Posted by romanmotruk
and that stopped producing red? they are not for sale
maybe it's a trade secret, but what is the total area of ​​the holes, the Reds pistons which equivalent pistons with conventional holes, 8 * 8 * 1.3 or 1.4?
I don't own a pair of red pistons but holes of the blue Mugen piston are 1.0mm. The width of the Vport is also 1mm, not sure about the length, but I could meassure it for you if you want that.
morgoth is offline
Old 03-24-2014, 06:45 AM
  #1922
romanmotruk's Avatar
Yes, measure, as far as possible, if you please!
why no sensible instructions on the site, which side to put the caps in struts why this important issue is not mentioned anywhere????
romanmotruk is offline
Old 03-24-2014, 08:14 AM
  #1923
CRP
CRP's Avatar
When you purchase CSI pistons you get a set of instructions that give you the info your looking for, with the exception of port sizing. All pistons are back in stock as of today.
CRP is offline
Old 03-24-2014, 11:15 AM
  #1924
Are the port sizes and piston holes the same size for all the 16mm pistons,and could you explain how different a 16mm shock feels/reacts with delrin square port vs aluminium square port please.
fastboy is offline
Old 03-25-2014, 04:46 AM
  #1925
CRP
CRP's Avatar
Hole sizes for both the Blue Aluminum V-Port and Blue V-Port Delrin are the same. The Aluminum V-Port features a sealing band which eliminates blow by, providing increased damping performance both on track and in our dyno testing results.
CRP is offline
Old 03-25-2014, 06:47 AM
  #1926
help me to understand, I think the last pistons are made so that upon compression piston was slower than in tension, or vice versa? I can imagine that this is sensitive information, but still I will explain
I ask a lot of questions, I'm curious to understand the meaning of ideas, not just to buy and put
Old 03-25-2014, 08:25 AM
  #1927
Ok thanks eric
fastboy is offline
Old 03-27-2014, 04:04 PM
  #1928
tropmonky's Avatar
Thumbs down 12mm Blue
Originally Posted by joykiller44
I bought the blue pistons for my B5m. I am NOT happy with them . I tried 30 -45 weight oil & all the associated springs.I went back to 1.4 3 hole tapered pistons.
I too have given up on my 12mm blue pistons. After looking at the holes very closely it appears that the tooling may have been spinning too fast thus melting the material and leaving flashing behind. Nearly none of the holes on mine are the same (yes I know 2 of the 4 holes are larger).
I too tried everything from AE 27.5 up to AE 37.5wt and I was unable to get enough pack with enough free travel in the shock. I tried AE rear White, Gray and BLUE. And on the front I tried AE Green, white and gray. Obviously with combinations between the two front and back. I ended up putting a drop of glue plugging up one of the small round holes in the rear pistons to try and get more pack and it helped somewhat, but I still felt they were unpredictable. I'm used to fancy pistons such as the fironi dual actions I use in my Pro4 Tekno and such, but I just couldn't get these to perform well for myself.
I've since switched back to the AE 1x1.6 pistons all around and I find it vastly better than the CSI's.
This is running at OCRC with about the best surfaces in indoor dirt hard pack racing.
tropmonky is offline
Old 03-28-2014, 06:29 AM
  #1929
CRP
CRP's Avatar
Wish you would have contacted us when you first purchased them a month ago and we would of taken care of you (exchanged). I definitely would not recommend plugging any of the holes to increase pack, most guys are running 32.5/35 Front and 27.5/30 Rear with great success.
CRP is offline
Old 03-28-2014, 08:02 AM
  #1930
Stubbs's Avatar
Trader Rating: 58 (100%+)
+1000000
Eric, and the guys at CRP put out very high qualiy stuff, but with any med-high volume production runs, there will be random quality rejects. Sometimes they're caught, sometimes not.
What is 100% accurate is that they have great customer support, and address quality issues right away.
If you find something that's potentially a manufacturing defect, don't just assume you have to deal with it.....send e-mails / PM's to CRP, and they'll get you squared away.
Stubbs is offline
Old 03-29-2014, 08:17 PM
  #1931
so i got he blue pistons for the xb9e whats a good starting point
billsharp34 is offline
Old 03-31-2014, 03:30 PM
  #1932
CRP
CRP's Avatar
37.5/35 Front
32.5/30 Rear
Ambient temps are going to play a key role with temps all over the board around the country this time of year.
CRP is offline
Old 03-31-2014, 06:52 PM
  #1933
Originally Posted by Stubbs
+1000000
No doubt! We haven't been running their stuff long but the customer service is top notch and the products are excellent. Great guys to work with
Austin's dad is offline
Old 04-17-2014, 02:36 AM
  #1934
Rubble01's Avatar
Hey guys I have a set of red pistons for my bmax4 ii
Any idea what I should start with oil wts f&r med grip rough track plz
Rubble01 is offline
Old 05-10-2014, 12:51 PM
  #1935
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I have a set of these for my 3.0. Now I have browsed and not found a definite answer.
Which side is the pack side.? There were no directions or info in the package, just pistons and a sticker sheet.
CSI-072-l-R squared v-port. Thanks.
UN4RACING is offline
