Old 12-12-2011, 04:24 PM   #1
Default thunder tiger eb4 s2 steering issue
Have a thunder tiger eb4 s2 buggy but stopped steering left now it only steers to the right.. Has anyone ran into similar issue?? what seems to be the problem?? Thanks
jfg429 is offline   Reply With Quote
Old 12-12-2011, 11:22 PM   #2
is this a rtr run transmiter you have with it i would look at the nob on the tx and put it in the center you could have move them if not it sound like you might have lost a gera in the servo most likley the sub c gear since they are made to give before the rest do in a metal servo any way if it plastic gear im sure you have mor than one bad one there look at the servo open it and see if it meatle you the sub c gear should be in the middle and the the post that the gear is on has some rigging in the to hold the gear once that rigging get a little striped one way or the other it done they are cheap to replace so best of luck
Team Argus
Team Rw- Mods |www.rw-Rw mods.com|
Hotbodies D8T Argus .23 | tb - 1 pipe|
Hotbodies D812
Hotbodies ve8 Tekin 2050
imrob is offline   Reply With Quote
