Xray XB9
#5431
i'm looking at hitec...
#5436
Anyone try the embue brass shock pistons in the X-ray shocks
#5441
I used the aluminum Fioroni 16mm made for Kyosho and they were best pistons I used. They have a replaceable rubber o-ring so aluminum never touches shock body. They were $100 bucks though, now I'd just by the new XB8 shocks. They are best I've seen.
#5443
i have a question about measuring ride height. seeing ranges between 23 and 28 mm but on mine with arms level i'm much higher even with the rear spring collar backed all the way off using 3 stripe progressive. is it measure normal or are the ride height numbers from xray based on the set up stand?
#5445
they're actually older springs. It just seemed odd to me that get proper ride height that the arms would be a good bit below level. Its my first 1/8 scale so i wasn't sure. i have the losi height gauge and just ordered the hudy blocks and droop gauge today along with some stock springs and the grey/blue springs. car worked pretty good overall just need to soften the brakes up to stop skidding to easily that caused some poor turn in issues. very impressed with the car
