Old 12-05-2011, 08:34 PM   #1
Unhappy Please help the Inexperienced!!!
I purchased a losi 8ight 1.0 used and trying to convert bo bump start from roto start. I got the back plate on and do not hear any rubbing in the motor but the engine was too high. I change to a 8ight 2.0 motor mounts but the box is still about 2-3 mm to low. Someone told me to try a mount by kink headz??, and said this would work. Does anyone want to tell me from experience or share if this will work? I just dont want to drop another 50 bucks on the mount and it be a simple fix.
Jase
RA9JAS is offline   Reply With Quote
Old 12-05-2011, 09:24 PM   #2
You know the wheel on the bottom of your buggy that's supposed to hit the bump box for it to start? It's called a flywheel. Get a bigger one of those and it will work
EatYoLegs is offline   Reply With Quote
Old 12-05-2011, 10:54 PM   #3
Trader Rating: 21 (100%+)
What bump box are you using? make sure its meant for 8th scale
TopGearRC is offline   Reply With Quote
Old 12-05-2011, 11:00 PM   #4
Sounds like the wrong flywheel to me also.
Other possibilities is the wheel needs to be adjusted higher in box, or a severely worn out wheel.
Franchise is offline   Reply With Quote
Old 12-05-2011, 11:17 PM   #5
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
The hing headz mount dont sit any lower then stock its just a better mount. Ur issues is either the flywheel is incorrect(not losi) or ur starter box wheel is adjusted to low or if its used theres a great chance its worn down. Its not the mount or engine, thats a flywheel or starter box issue.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 12-06-2011, 02:26 PM   #6
Slider30250's Avatar
One other thing that no one has mentioned is just making sure that the opening in the chassis for the engine flywheel is centered over the starter box wheel.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 12-06-2011, 02:50 PM   #7
uh hey the problem is you still have rotor start back plate still on engine. have to convert engine to bump start back plate. rotor start back plate wont let engine sit low enough to get starter box to work.
K and K racing Kyosho MP9 tki2 BCE chassic Losi xxx sct Hot Bodies D4 I love this hobby!!
losi8ight2.0 is offline   Reply With Quote
Old 12-07-2011, 05:00 PM   #8
Flywheel is stock. Im using 2.0 mounts(shorter than the 427 and have the backplate on. I tryed to bump it and the wheel looks as if if the wheel is being stopped by the chassis. I read another thread that says they had to mill the hole a bit bigger because of the same problem. I just wasn't sure if the kings mounts were shorter, and if anyone had encountered this.
Old 12-07-2011, 05:10 PM   #9
Best way to see if issues are occuring before ot gets to the engine is take engine out, and line box up with engine out and see if wheel gets in like 3mm without hitting chassis.
Old 12-07-2011, 06:09 PM   #10
Jaz240's Avatar
Trader Rating: 52 (100%+)
I converted My Nephews Losi 1.0 RTR to a Bump start. I had to grind out the Flywheel hole in his chassis quit a bit. Took about 4-5MM off each side to allow the starter wheel into the chassis
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 12-07-2011, 06:12 PM   #11
Frank L's Avatar
Trader Rating: 148 (100%+)
I had that same issue when I wen to losi using a bump start enine with an ofna chrome top box. I ended up raising the mech inside the box that the wheel spins on so the wheel stuck out more. Solved the issue with that box. Btw never had an issue with the ofna blue truggy box on losi.
Take the engine out and line up the box so you can see the wheel come through then try it again. I don't think the kHz mount is shorter.
Old 12-07-2011, 06:13 PM   #12
I tried it with the motor off. Its actually stopping the starter box because its rubbing the chassis. It's an ofna box if that helps. It looks like I have everything else right but have to grind the slot out a bit. Will it hurt how the car handles? Or, do you have and other suggestions? All your help has been very greatful thus far.
Old 12-07-2011, 06:17 PM   #13
Jaz240's Avatar
Its actually easy with a dremel. Get a nice big grinding bit and just go to work on the slot the flywheel sits in. It does take awhile and you should completely take apart your car so all you have is the chassis. You dont want any of those metal shavings working their way into any other parts. Wear glasses and have at it. Keep grinding and testing it on the box and you will see when its good.
Old 12-08-2011, 03:09 PM   #14
Default Strike two...
Ok everyone, this was actuall an error on my part because the mounts on the box were not right. I have the blue box. Next issue:
I got everything back together(did not try to roll the car)
The wheels are locked when trying to roll them all the same direction. You can roll two but not all four. Please don't give me any bad news. Also, I thought that I got a good deal on a car that ran, buying a 1.0 for $220. I received it today and it has the spin backplate also. I tryed to spin in and when it goes to engage fast it is only spinning. Not turning the motor over.
Old 12-08-2011, 04:04 PM   #15
Default Also...
Forgot to mention that I installed a new clutch...if it helps
The TLR 22 Guide Thread Muggydude Electric Off-Road 62 10-24-2015 09:08 PM
Traxxas Slash spec class racing at Ryde in 2009 and beyond Roman Australian Racing 2293 02-20-2013 05:18 AM
THREE OPTIONS [PLEASE HELP] a.howard Nitro Off-Road 24 06-10-2009 02:55 PM
