Old 12-01-2011, 11:34 AM   #1
Default droop questioni
Is there any type of tool simular to onroad to set the droop, if not what is the best way?
2011 Caster Team Driver
offroadborn is offline   Reply With Quote
Old 12-01-2011, 11:42 AM   #2
morgoth's Avatar
Meassure shock lenth or use 30mm droop support blocks.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 12-01-2011, 11:44 AM   #3
Would amain have the blocks?
Old 12-01-2011, 12:39 PM   #4
nitroexpress's Avatar
http://jq-products.com/the-home/35-n...owntraveldroop
nitroexpress is offline   Reply With Quote
Old 12-01-2011, 12:56 PM   #5
morgoth's Avatar
This are the blocks and then with a ride height meter you can meassure between the setup board and the hubs.
I meassure droop with a ride height gauge under my hubs on my onroad car, but with calipers on my offroad cars. Just meassure the length from center hole to center hole.
Most people measure the shocklength in offroad so that's a little compare setups when you it in the same way. And it's cheaper
There are the droopblocks if you want them: http://www.amainhobbies.com/product_...pport-Blocks-2
Old 12-01-2011, 09:36 PM   #6
Thanks for the help
Old 12-02-2011, 06:31 AM   #7
Go to your local hardware store and buy 30mm square tubing. That's what I did and is heaps cheaper. Just have to cut it. Easy
ratjayfala is offline   Reply With Quote
Old 12-02-2011, 06:36 AM   #8
Try the JQ method.
http://vimeo.com/32276751
__________________________________________
Did you bother to read the fine manual yet? (RTFM)
bentgear is offline   Reply With Quote
Old 12-02-2011, 08:37 AM   #9
pgk
Originally Posted by bentgear View Post
Try the JQ method.
LOL Looks like the guy in the background of this video is taking a leak! Check it out...
pgk is offline   Reply With Quote
Old 12-02-2011, 10:17 AM   #10
I wonder how many times JQ had to reshoot for everything to work out the way it did.
Old 12-06-2011, 06:11 PM   #11
Thanks will do.
Old 12-06-2011, 06:39 PM   #12
Jeauxkor's Avatar
Trader Rating: 29 (100%+)
That dude was so taking a leak!!!! Lmao!!
Jeauxkor is offline   Reply With Quote
