Old 11-30-2011, 01:09 AM   #16
Nitro Tiger's Avatar
Originally Posted by Redxz View Post
I use these to take out the slop, comes with various sizes.
http://www.amainhobbies.com/product_...mm-Shim-Set-10
I put the shims between the hex, and hub bearing. Make sure everything rolls smoothly when your done. I went over board one time and removed all the slop, and found when I tightened down the grub screw in the hex that things bound.
Instead of special metal disks I use CD's
Ive done that on both my buggys, my Xray had slop from new but as you said you must make sure you dont make it bind on the bearing. Takes alot of slop out when shimed properly.
Wade Lazich- NSW 1/8 IC State Delegate.
Thankyou for your support- Werks Racing USA/ Pro Rc Supplies/ Aka Aust./ Ryper Hobbies
LRD- Australian distributor of Werks Race Blend 30% fuel. Dedicated solely to the supply of racing products for 1/8 scale nitro Rc. -lazrd.com.au-
Nitro Tiger is offline   Reply With Quote
Old 11-30-2011, 02:36 AM   #17
johnny t's Avatar
Originally Posted by alport78 View Post
As you all know our buggy tires have a little slop so you can move the top point of the tire inward or outward. This slop change the camber at least 1 degree. On which position do you measure the camber ? after forcing the top of the tire inward our outward?
The way wheels lever on the suspension places the upper links in tension. Same thing happens whether at rest or in cornering. So to answer your question you force the top of the wheel out. Although that's only necesary if you are using a hudy like setup station or discs, as they load the suspension opposite of what a wheel actually does. Negating thier usefulness IMHO.
johnny t is offline   Reply With Quote
TA-05 ver.2 RepaF1 Electric On-Road 2704 05-06-2017 05:25 PM
QCRCCC OFF-ROAD RACING emer Manila Racers 16543 04-08-2016 12:31 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 03:31 PM
