Old 11-28-2011, 02:58 PM   #1
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Default Swaybar ???
If you move the mount the swaybar goes thru on the suspension arm a little I.E. letting more bar stick thru or less bar stick thru will it change the rate pf the bar any? I only have the stock bars for my Xray XT8 '09 and I'm racing on a smooth indoor track this Saturday and don't have time to get new bars ordered? Here's a pis of the mount I'm talking about, Thanks
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 11-28-2011, 03:15 PM   #2
if you consider the rules of leverage, the position of the ball ends does have an effect. The further away you set the ball end, the softer the bar will feel and vice-versa. moving in the ends are common in on-road to get the L/R load to balance. You don't need to balance in off road I think. Just make sure your suspension isn't binding after the adjustment.
redbones is offline   Reply With Quote
Old 11-28-2011, 04:21 PM   #3
OfnaJoe's Avatar
That's what I was thinking, so if I push the ball back and let more of the swaybar stick thru it will make the bar act harder, right ?
And thanks for the reply.
Old 11-28-2011, 05:50 PM   #4
ronsand's Avatar
That is to some extent correct, but it is center part of the swaybar that's twisting (torsion bar) more than the ends bending.
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 11-28-2011, 06:13 PM   #5
rfleck's Avatar
If there are no big jumps and it is smooth, you may want to limit the droop too
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 11-28-2011, 06:21 PM   #6
tc5 man's Avatar
I done it on my Rc8tce with pushing out the collers out a little on the front end i did because i felt with the collers pushed out the front end dint feel responsive enough now i coverted my to electric so its not the same balance . But on a rough track it actually made the front end to responsive with collers out more.
So you just have to test it out to see.
With collers in more it will make the supension arms react more like a sway bar.
On a smooth indoor track like yours im thinking moving it in will ethier help or not help it depends on if you feel the front end is lacking on responsive or not.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 11-29-2011, 01:36 PM   #7
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
on the xt8 i raced last year, i removed the front sway bar and ran the 3mm sway bar in the rear...the turn in was much better and it didn't push nearly as bad, made it easier to drive harder...
i was running 3mm of bar sticking out of the ball ends for the rear
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Old 11-30-2011, 06:00 PM   #8
OfnaJoe's Avatar
Thanks I will give that a try
Hot Bodies Cyclone TC roller with original box, manuals, extra parts, swaybar sets TJames987 R/C Items: For Sale/Trade 15 05-11-2009 02:32 PM
Revo swaybar bobbyblaze Monster Trucks 23 07-29-2008 10:18 PM
MUGEN/Kyosho SWAYBAR-TOOL YBSLOW Nitro On-Road 23 10-29-2007 09:41 AM
