Old 11-01-2011, 08:32 AM   #1
gregorys's Avatar
Questions?? 8ight 1.0 Servos - advice
Just looking for some suggestions for a steering and the throttle servo for a losi 8ight T 1.0.
I've been doing some research on this subject and have mixed feelings.
I've noticed the stock servo's in the 1.0 are the Z650M. What would you guys recommend running? Would this be okay for a throttle servo and maybe i should sped a little bit more money on the steering servo?
Just looking for some advice for trial and error of others.
Thanks!
gregorys is offline   Reply With Quote
Old 11-01-2011, 09:23 AM   #2
ironzgti35's Avatar
Trader Rating: 20 (100%+)
If your not racing or on a budget, get 2 hitec 5645's and be done with it. should only cost about $80 and they hold up just fine in my losi 8ight's and as a throttle servo on my baja.
ironzgti35 is offline   Reply With Quote
Old 11-01-2011, 10:00 AM   #3
ghost68's Avatar
Use the thick plastic shims under the throttle servo (even though is says you dont need them) and dremel away the side guard where it comes close to touching the servo so there is no way it could ever touch the bottom of the servo and you should be good to go.
-Dustin Bullard
***HoBao Hyper Star/JL .21PRO/2047/Savox/AKA***
I would like to say Thanks to my sponsors: Team OFNA and Sidewinder Fuel
ghost68 is offline   Reply With Quote
Old 11-01-2011, 01:55 PM   #4
gregorys's Avatar
I started looking @ the servo's you suggested.
Should i just bite the bullet and upgrade to a HV servo?
http://www3.towerhobbies.com/cgi-bin...P?I=LXZTZ1&P=8
Seemed to be only a few more dollars?
Old 11-01-2011, 01:58 PM   #5
stallen50's Avatar
Trader Rating: 30 (100%+)
Savox servos. Dont go cheap on servos otherwise you would be spending more replacing them then buying good ones. I had a z650 that only lasted 3 days
agama a8 usa edition
Arrow gtr.21, os speed
savox servos
thanks to my 2013 sponsors: vp-pro tires, hobbypro usa, beta tires, arrow racing, team terribles, boca bearings
stallen50 is offline   Reply With Quote
Old 11-01-2011, 02:04 PM   #6
Frank L's Avatar
Trader Rating: 148 (100%+)
Due to the depth and Poole that blow servos in the 8 cars I would use savox 1286's if you want hv and 1256 if you want to run nimh.
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
How to start racing 1/8 scale nitro buggy patmyas1 Nitro Off-Road 45 11-12-2010 07:34 AM
New purchase need advice coming back after 8 years. Ananda Robinson Nitro Off-Road 128 05-16-2010 01:28 PM
Losi 8ight 2.0 RTR throttle servo jared52 Nitro Off-Road 23 02-13-2010 03:11 PM
