Old 10-29-2011, 11:11 AM   #1
AgamaRC's Avatar
Smile Brake Adjustments Agama
Hi has anyone put a thread out there for setting up Brakes and EPA's I am having a few problems with my servo must be doing something not quite right Does anyone have the low down on setting these for the Agama EVO 8
AgamaRC is offline   Reply With Quote
Old 10-29-2011, 11:50 AM   #2
jmaxey51's Avatar
are you just not getting strong brakes or what? ... i know with Agama you have to cut a coil or two off the spring between the brake pads. if you dont the springs bottom out and no mater how you set EPA, brakes wont work well. i cut about 1.5 coils off mine.
hope this helps.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 10-29-2011, 01:22 PM   #3
AgamaRC's Avatar
Smile
Yer the problem is Im not getting strong brakes and Im having to set my EPA on the transmitter far higher than I think is acceptable, worried about blowing a servo. Cutting the coils is a great idea. The simplest solutions an all that, just makes you wonder why Agama sell springs that are to long for the job.
Old 10-29-2011, 01:52 PM   #4
Jaz240's Avatar
Trader Rating: 52 (100%+)
removing the springs completely wont hurt anything either. Also the fuel tubing supplied in the kit for the brake linkage is too soft. Find a stiffer tubing. You should be fine after that.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 10-30-2011, 03:56 PM   #5
imaxx21's Avatar
Send a message via AIM to imaxx21
the springs aren't too long, just need to screw the screws in more...making the gap between the plates smaller
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 10-30-2011, 04:09 PM   #6
jmaxey51's Avatar
they are to long, well to many coils... even Gene Hickerson said that, he posted to cut 1-2 coils off.....
Old 10-30-2011, 04:15 PM   #7
imaxx21's Avatar
who's he? mine aren't cut, and brakes work perfect, just sayin
-Crash
Old 10-30-2011, 04:27 PM   #8
jmaxey51's Avatar
the team manager for Agama, and ours did too, but if the brake pads wear any, brakes fade... and once we cut coils off, it would stop on a dime
NEW AGAMA A8 BUGGGY rc_cal Nitro Off-Road 10213 07-13-2016 12:30 PM
