Old 10-25-2011, 08:01 PM   #16
shady3031's Avatar
Trader Rating: 26 (100%+)
i'd be interested in some 4x10 and 4x12 button heads, used to hold the steering blocks into the caster blocks on the associated buggy. Seems without red loctite in the hole, one of them seems to work its way out.
The Warehouse RC-Birmingham, AL
AE RC8.2-E Tekin powered
Alabama Manufacturers Shootout-Don't Miss It
shady3031 is offline   Reply With Quote
Old 10-25-2011, 08:10 PM   #17
PM me your address and I will send you some to try out.
Tim35 is offline   Reply With Quote
Old 10-25-2011, 08:25 PM   #18
Brushless420's Avatar
Trader Rating: 169 (100%+)
Originally Posted by Tim35 View Post
Hey Guys,
I've ordered the following screws for processing. Let me know which ones you are interested in testing for me. I should have these ready in less than 2 weeks.
M3x6mm Flat Hd. (countersink) Skt.
M3x6mm Metric Button Socket Screw
M4x12mm Metric Button Socket Screw
8-32x3/8" Flat Hd. (countersink) Skt. Screw
8-32x1/2" Flat Hd. (countersink) Skt. Screw
M3x10mm Flat Hd. (countersink) Skt. Screw
M2x4mm Socket Head Cap Screw
4-40x1/4" Socket Head Cap Screw
Both of these would be great.
Brushless420 is offline   Reply With Quote
Old 10-26-2011, 04:53 AM   #19
I would be interested in these little guys. LMK.
Revooooooo is offline   Reply With Quote
Old 10-26-2011, 08:00 AM   #20
Integra's Avatar
Originally Posted by Brushless420 View Post
Huge problem on the SCTE. The factory hardware is garbage in the first place. The next is hardware backing out going into the diff cases. This is especially bad when running indoor on carpet. Both for the mishandling and tearing up the carpet. The screws are 8-32 x 3/8" Flat head and 8-32 x 1/2" Flat head.
100% False, Yes the Diff cup screw's can strip if your using a Dull Worn out driver, BUT to claim all the hardware is Garbage is Not True by any stretch of the imagination. The SCTE screw's are the exact same found on the 1/8 cars and are Just fine and dandy if you have the proper sized driver's.
Old 11-09-2011, 04:50 PM   #21
Default Good News!! The Screws are ready!!
Hey Guys,
I should receive the screws tomorrow and I will be sending them out to all of you who requested them on Friday. I look forward to your test results in the near future and maybe these screws will solve some of your current issues with Loctite.
Thanks,
Tim
Old 11-10-2011, 05:31 PM   #22
Default The Screws are ready for shipment
To all:
If you are interested in trying any of the sizes below please send me your address if you haven't already. I'm sending out the screws tomorrow to those I have their address already.
Old 11-11-2011, 05:48 AM   #23
Redxz's Avatar
All the areas I can think where I would want this are:
Servo saver posts- bottom M4x10 (countersunk), top M3x12 (countersunk).
Motor mount- bottom though chassis M4x10 (countersunk), top motor screws M3x12 (caphead).
Grub screws for CVD's M4x4,and M5x4.
Pipe hanger bottom through chassis M4x8 (countersunk), and M4x4 grub.
This seems to be the normal sizes for most kit.
Redxz is offline   Reply With Quote
Old 11-11-2011, 06:10 AM   #24
hookem34's Avatar
Trader Rating: 17 (100%+)
+1 on those, especially the CVD grub screws.
Dan Culver
Companies I stand behind with my hard earned cash:
KyoshoClockwork Racing EnginesPT Racing OilsJet Lube ☆ Futaba ☆ Competition Heat ☆ Revolve RCNovarossiBuku PowerBones Motorsports
hookem34 is offline   Reply With Quote
Old 11-11-2011, 06:49 AM   #25
I would use Locktite for piece of mind.
geejay is offline   Reply With Quote
Old 11-11-2011, 08:01 AM   #26
Redxz's Avatar
But, wouldn't it be nice to not have to, and be able to reuse it 100 times!
If it really works as stated then you would have piece of mind.
Some people have roported that their motor mount screw back out even when locktited.
Old 11-11-2011, 11:49 AM   #27
According to the guys who designed the application it is far superior to loctite. This is a military grade applicaiton not consumer grade as is the case with loctite. Now there are a few different applications we could try on the motor mount screws if the first round of tests doesn't work. The application on these screws is an all around app, we also have sealents, high heat, permenant locking, etc.. If it works as it has in the past on real planes, jets, etc.. I don't think there will be any issues.
Old 11-28-2011, 08:59 AM   #28
Default Screw Tests
To all:
Hopefully everyone who requested the screws for testing has received them by now. Also, I was wondering if anyone has any test results from the screws and locking ability of the compound.
Thanks,
Tim
Old 11-30-2011, 08:55 PM   #29
JonesyCGY's Avatar
Hi Tim,
Got your screws you sent me up to Canada. Just wanted to say thanks.
I only run on-road carpet 1/12th scale and 1/10 EP Touring. I have already installed the screws you sent onto the rear wheels of my 1/12th scale.
The screws seem to be really excellant quality first off. They fit my normal sized 3/32" wrench which was nice. I ended up removing the screws again today a day after installing them(to change ride height) and they came out with resistance as expected and the blue loctite was still intact. I was expecting the loctite to be a powdery mess but it wasn't. I take it thats normal?
I am attending a full weekend race event this weekend and will try the rest of the screws you sent me and let you know the results.
Tamiya M-03R // BMI DB12RR // AE TC5R // AE TC6.1
JonesyCGY is offline   Reply With Quote
Old 12-01-2011, 01:04 AM   #30
Hey JonseyCGy,
Thanks for the post on the screws! The blue coating should not come off under normal conditions at all. The only way to get it off would be to take it to the grinder and remove it. Also, the screws should keep their torque strength for about 100 removals or more so they shouldn't come loose anytime soon. I'm happy you like the screws also, I tried to find the highest qualitity avalaible to match with the blue coating so I could get a real test and provide a good product. Let me know how the testing goes, I know its a busy time of the year with the holidays so I expected things to be slow. Let me know if you have any questions or issues.
Tim
SC10 4x4 Thread CraigV Electric Off-Road 36430 07-21-2017 09:50 AM
The TLR 22 Guide Thread Muggydude Electric Off-Road 62 10-24-2015 09:08 PM
The SC10 4x4 Guide CraigV Electric Off-Road 9 09-10-2014 10:00 PM
