Old 10-14-2011, 08:49 PM   #1
Seattlelife22's Avatar
Trader Rating: 25 (100%+)
Default Putting the grooves on the back of 17mm nuts?
I use lock tight on losi 8ight but i just want the added protection. Someone did a how to in car action along time ago. My question is where is a how to? I have searched and the only thing i can come up with is the ofna ones but i dont want those. thanks for the help.
Seattlelife22 is offline   Reply With Quote
Old 10-14-2011, 08:55 PM   #2
captain america's Avatar
You can do that easily with a Dremel and a cutting wheel, just score the back face of the nut. If you want the easy way out, just buy 'Rango wheelnuts.
captain america is offline   Reply With Quote
Old 10-14-2011, 08:56 PM   #3
rider313's Avatar
Trader Rating: 94 (100%+)
You can buy them for like $15.
Otherwise take a vise grip and hold the wheel hex and use a dremmel and a cut off wheel to make grooves. Go straight across the hex 4 or so times.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 10-14-2011, 09:01 PM   #4
Integra's Avatar
HB or HPI wheel nuts are what your after, They Will LOCK the wheel in place if you crank on them a little too hard, I use a 800 ft/lbs Makita Impact driver for my tires and That sometimes even takes a few seconds to remove if I went a little too long when tightening.
http://www.amainhobbies.com/product_...el-Nut-Black-4
Old 10-14-2011, 09:38 PM   #5
Trader Rating: 47 (100%+)
800 ft/lbs ? .......................
rageworks is offline   Reply With Quote
Old 10-14-2011, 10:21 PM   #6
Trader Rating: 39 (100%+)
I'm going to guess that he has something similar to this.. In which case it's 800in/lbs, a huge difference, but easily mistaken or mistyped.
BrakeTurnAccelerate is offline   Reply With Quote
Old 10-14-2011, 11:30 PM   #7
ghost68's Avatar
Just a fyi : do NOT get OFNA wheel nuts for a Losi... They use different thread patterns and aren't interchangeable... While actual serrated wheel nuts will be better you can definitely get away with scoring the back of your wheel nuts to make them serrated yourself, even better score both sides and you will never have to worry about putting them on backwards
-Dustin Bullard
***HoBao Hyper Star/JL .21PRO/2047/Savox/AKA***
I would like to say Thanks to my sponsors: Team OFNA and Sidewinder Fuel
ghost68 is offline   Reply With Quote
Old 10-15-2011, 01:12 AM   #8
slow coach's Avatar
you want the mugen ones they are proper locking wheel nuts you actually see where they bite into the plastic, they aren't grooved on the back the serrations actually stand proud of the surface and this is what holds them in place.
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 10-15-2011, 02:02 AM   #9
neobart's Avatar
Or you could get the closed wheel nuts Losi makes. You don't need to use a lot of force to hold the wheel in place.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 10-15-2011, 02:38 AM   #10
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
You can just use a nail punch and put a pile of divots in the back of the nut
That helps them grip into the plastic
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 10-15-2011, 06:47 AM   #11
Integra's Avatar
Yup, My bad 800in/lbs.
Old 10-15-2011, 07:05 AM   #12
Integra's Avatar
FYI there are 2 different threads for wheel nuts, Coarse and Fine.
Losi, HB, HPI, Serpent, durango and a bunch more use Fine.
Old 10-15-2011, 07:15 AM   #13
rider313's Avatar
I have also been using the Bosch 12V mini impact lately at the races to for wheel nuts. It is slick.
Dan Williams
MNRC Chairman
Old 10-15-2011, 07:32 AM   #14
MadRussian's Avatar
iirc all are fine thread except for Z-Car, and Ofna.
MadRussian is offline   Reply With Quote
Old 10-15-2011, 07:41 AM   #15
I use this little baby to change the tires on some of the heavy
equipment that I service. It does look rather intimidating sitting
on the pit table though.
http://www.louzampini.com/CP5000-Sup...-p/t024585.htm
