Old 10-13-2011, 01:10 AM   #1
Default 1/8 Nitro Buggy brake bias
I know there many things to be taken into consideration when setting Brake Bias but what would be a good starting point for a novice just learning to set up his buggy.
Nitro Basher is offline   Reply With Quote
Old 10-13-2011, 01:19 AM   #2
TV
40% front and 60% rear is generally standard issue. When setting the brakes, hold full brake and roll just the front tires against the ground and they should barely roll but with a lot of resistance. Do the same with the rear except the rear tires should lock up.
TV is offline   Reply With Quote
Old 10-13-2011, 01:19 AM   #3
merdith6's Avatar
Default Great question...
You want the rear to have the strongest braking force without locking up, but still pretty strong....and the front is really up to you. I like the front to be a bit soft because if it's too strong the car will push in the turns. If you set it up like that it will slow down at the end of straits without sliding sideways and yet still allow you to use the brakes in the turn to help pivot...Set it up like that then if you need more front brake dial some more in...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
HPI Vorza Flux 1/8 E-Buggy Thread H0LESH0T Electric Off-Road 11249 07-23-2017 01:50 PM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
Brushless conversion for 1/8 nitro buggy HookaMega Nitro Off-Road 11 04-24-2008 10:54 AM
