Old 10-11-2011, 11:04 AM   #1
bcarter007's Avatar
Trader Rating: 96 (100%+)
Default HB D8T shaft or outdrive????
hey ive got a issue going on with my modded setup and was wondering if anyone knows of a aftermarket drive shaft (kyosho xray ect...) that may be a little longer than the stock 131mm hb shaft or maybe a 2-3mm longer outdrive that will fit in the hb diff case with no problems? im running the mugen rear shocks on my d8t and love the travel and droop it gives me but im right on the edge with this.....ran 2 races and had shaft pop out due to it being way to close on the edge of the outdrive.....just wondering if any of you guys are doing this and have a idea for a fix...thanks
Rangers Lead the Way!! Team Hotbodies Driver Hara D8 OS Speed XZB Hara Ed D8T OS Speed XZB Hara Ed Ve8 Tekin RX8 1400kv UP Grade Graphics Hitec DX3R PRO RayAracing.com RAPICON 30/9 Race Blend Jammin SCRT10 4x4 Tekin RX8 4.5T SMC Hotbodies Tires Thankyou HPI-Hotbodies & Pro-Line
bcarter007 is offline   Reply With Quote
Old 10-11-2011, 02:21 PM   #2
Torian4000's Avatar
Trader Rating: 49 (100%+)
You could try these Losi 8T 2.0 drive shafts.
http://www.amainhobbies.com/product_...shafts-2-8T-20
I believe they are a tad bit longer than the D8T drive shafts but don't quote me on that. I do know they will couple with the HB axles. I run a losi 8t rear center drive shaft on my Hara D8 because it's more heavy duty than the HB shaft and the losi drive pins/set screws are stronger. They fit right into these HB units... http://www.amainhobbies.com/product_...-Shaft-Coupler
http://www.amainhobbies.com/product_...-Bodies-Axle-1
Torian4000 is offline   Reply With Quote
Old 10-11-2011, 03:27 PM   #3
bcarter007's Avatar
ok so the losi 8 2.0-T drive shafts are a bit longer? hmmmm i wonder if the losi outdrives are longer?
Old 10-11-2011, 03:41 PM   #4
Trader Rating: 104 (100%+)
I have both. Will measure tonight for you if someone doesn't chime in.
ROSCOE is offline   Reply With Quote
Old 10-11-2011, 05:01 PM   #5
bcarter007's Avatar
yes please measure the outdrives and shaft that u have...thanks
Old 10-11-2011, 05:05 PM   #6
brandundecided's Avatar
reduce droop...dont wreck
brandundecided is offline   Reply With Quote
Old 10-11-2011, 05:14 PM   #7
bcarter007's Avatar
if uve got nothing intelligent to say then dont post
Old 10-11-2011, 05:45 PM   #8
aptyk88's Avatar
Trader Rating: 17 (100%+)
i have also had the same problems since switching to the longer droop on the d8t, and i broke 2 shafts...
Mugen Seiki
Bones brew
OS speed
Futaba
aptyk88 is offline   Reply With Quote
Old 10-11-2011, 05:57 PM   #9
Losi 2.0 shafts measure 143mm from pin center to pin center. D8t measure around 133. The reason for the difference is the outer pin being captured by hub bearing on the 2.0 hence a longer shaft. I will scope out the out drives for you.
Old 10-11-2011, 06:35 PM   #10
bcarter007's Avatar
thankyou
Old 10-12-2011, 03:30 AM   #11
neobart's Avatar
Maybe try Xray outdrives. I know they have a longer outdrive for the XT8 for the front diff. Has about 3mm extra to it.
http://www.amainhobbies.com/product_...g-Steel-Long-2
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 10-12-2011, 03:23 PM   #12
RC-BATT's Avatar
Bryce i can measure a mugen out drive for ya?
Mugen MBX7R//rw-mods.com
REX Racing//Futaba//Hitec//Pro Match Racing
Darkside Designs//Rapicon Race Fuels
JPC The Midwest Monster
RC-BATT is offline   Reply With Quote
Hotbodies Ve8 Thread joelwhite Electric Off-Road 13618 04-02-2017 06:46 PM
HHH Racing Chassis HH Electric Off-Road 1536 08-06-2014 08:50 AM
