LRP S8TX bodies
hi i was just wondering what sort of bodies i could use for the truggy?
i have the pro version (the standard chasis) i have heard that people are using the MBX6T bulldog body but with the extended chasis. would anyone have any ideas what to use? cheers Mark |
I ran a rc8t bulldog when I had the Z truggy and it fit nice with alittle trimming. I did have the extended chassis (22mmm longer I believe). I would think you could make it work with the standard chassis. Good luck.
cheers for the info Roscoe/
do u know if any of the bulldog bodies would fit? i.e- d8t, mbx6t, 8t etc, etc im a newbie to the sport but i want a body that would fit nice without to much modification and make it stand out from the crowd lol cheers for the help Mark |
Like I had mentioned mark, the AE RC8T Bulldog is what I used on my zmxt8 (same as your lrp). I don't think that any of the bulldogs will fit any better than the next as all will require alittle handy work. It has been some time since I had mine but the losi bulldog with losi 8t 2.0 front body mounts might work the best. It would also eliminate the crater for the front body clips which is a pain with the rc8t and d8t bulldog bodies. Hope that helps.
1 Attachment(s)
I run the SH ZMXT truggy newer version with ext chassis and J concepts punisher MBX6 body is what I use with no extra trimming.
thanks for heads up guys.
thinking i might have to invest in getting the extended chasis does anyone know how much they are? cheers Mark |
They are $85 on atozrc.net. The chassis super light vs stock and makes the truggy easier to drive. Good $85 spent I think.
thanks for the help guys
cheers Mark |
