Old 10-08-2011, 11:21 PM   #1
Mind_Reader7's Avatar
Default How do I remove this?
The part circled in red, I need to remove it, how do I do it?
Also, what's it called?
Mind_Reader7 is offline   Reply With Quote
Old 10-08-2011, 11:29 PM   #2
Hal Hudson's Avatar
It's caled a collet. take a small knife or screw driver and open up the slit and it will come off.
Owner of the World Famous Hudson Hotel.Home of the
2012-13 Northwest Short Course 4x4 SC Champion
2012-13 NCT Stadium Truck Champion
2013 NCT 2WD Buggy Champion
2012 NCT 4x4 Buggy Champion
Hal Hudson is offline   Reply With Quote
Old 10-08-2011, 11:30 PM   #3
It's a collet (normally brass).
Insert a flat head screw driver into the slit and twist it to get it loose. You should be able to get it off after that.
Edit: I got beat to it. Typing on a cellphone is slow
jbeesix7one is offline   Reply With Quote
Old 10-08-2011, 11:32 PM   #4
Thanks!
Old 10-08-2011, 11:34 PM   #5
madac's Avatar
That would be a clutch collet that goes again the front bearing washer and it holds the flywheel tight to the engine crankshaft. I usually use a small flat head screwdriver and put it in the slit and twist until it comes off the drive shaft and slide it up with the screwdriver in place until it's off. Hope that helps.
Philip
Team Associated B5
Spektrum DX3S
madac is offline   Reply With Quote
How do I remove anodizing? Peter Busch Chat Lounge 33 11-23-2008 08:21 AM
HOW DO I REMOVE A FLYWHEEL??? HELP PLZ paul73rc Nitro On-Road 15 06-23-2007 07:33 AM
