Old 10-08-2011, 01:53 PM   #1
Default glued tires and they didnt stick.. why?
I got some cheap tires/rims off ebay from china.. it said they were glued but they were not.
so I also bought some glue. its not the normal clear stuff.. its black. this is it: http://www.ebay.ca/itm/BSI-IC-2000-R...item3a6a2b62a7
anyways, I tried gluing 2 tires yesterday... seemed to go good. I waited an hour or so for them to dry and I went to see how well it had worked.. I pulled on the tire and the glue cracked right off like it was nothing, it was very brittle. it stuck to the tire very well, but not to the rim at all. why?
thanks.
whatsitallworth is offline   Reply With Quote
Old 10-08-2011, 02:13 PM   #2
warnked's Avatar
try washing the rim with dish soap, some manufacturing processes require a lubricant to be sprayed on the mold in order for the plastic to separate cleanly. you can rough up the edge that contacts the tire bead with sand paper for better results also.
AE B4.1 Worlds, Losi XXX-T CR, Tamiya F104, Jammin x1x, HPI rs4 evo+
warnked is offline   Reply With Quote
Old 10-08-2011, 02:18 PM   #3
Moderator
Muggydude's Avatar
Trader Rating: 89 (100%+)
You need to rub the tires (and rim) beads down with some rubbing alcohol real good to get off all of the molding agents left over from manufacturing. Use some paper towel to do it. You'll be amazed how much of the stuff comes off.
AKA tire glue has always worked really well for me.
Muggydude is offline   Reply With Quote
Old 10-09-2011, 08:29 AM   #4
scwrod's Avatar
Get some real CA glue. The stuff you are using is not bonding to plastic. If that stuff was any good we would all be using it
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
damn tires... Mugen MBX-5 Nitro Off-Road 26 03-11-2008 03:10 PM
