Old 10-03-2011, 07:57 PM   #1
Trader Rating: 32 (100%+)
Default Question on Tire wear vs Camber
Drove my car pretty hard this weekend, Setup the camber on the Hudy station, -4.5 rear and -3.5 Front. When I look at my tires, I see the Rear tires wore out in the middle slightly favoring the outside of the tire versus the inside, the front tires wore out straight down the middle. I feel the car was hooking up good, but I feel it was possibly a driving error from traction rolling, and the camber gauge would have probably said -3, -2 versus the hudy. Does that mean I need to add some slight negative camber, maybe move to 5.0 rear and 4.0 front on the Hudy to get optimal tire wear?
Retired - 9.5Pro -> Jammin X1 -> Jammin X2 -> AE RC8B -> Serpent S811 Cobra -> Hotbodies D8 -> 2010 XB808 -> 2011 XB808 -> 2012 XB9 // 2012 XB9-E, Current Vehicles -> 2013 XB9 // Converted 2013 XB9E
mcion is offline   Reply With Quote
Old 10-03-2011, 08:12 PM   #2
beidle99's Avatar
That is some pretty dramitic negative camber numbers. I normally use 0 to -2.5 at most. Your front might be OK if the centers wore out, but your rears sound to have to much. You want your tire to ware evenly. To much negatve can be bad as well for handling.
Mugen MBX7R, Fusion X5 Race "FM", Houston's Engine Service, 2096/41021, Buku Komp
Mugen MBX7 Eco, Hobbywing XR8, SMC 1900, BCE X3.
Team Driver for FusionX Engines & BCE (RIP Bill)
beidle99 is offline   Reply With Quote
Old 10-03-2011, 08:55 PM   #3
captain america's Avatar
It's normal that tires will wear in one area more than another; they aren't necessarily meant to wear evenly, as this would indicate too big of a contact patch (surface dependant, of course), resulting in unnecessary resistance and lower speeds. When your wheels have negative camber, because tires have a crown, it narrows your track, whereas positive camber has the adverse effect. It's generally preferable to run the rear wheels with very little camber and a little more in the front, but in the end whatever setup gets you fast laps is the hot ticket.
captain america is offline   Reply With Quote
Old 10-03-2011, 09:47 PM   #4
merdith6's Avatar
Default eeeeh
I like to run the front with less negative camber than the rear. usually I never mess with that adjustment. about -1 in the front, and -2 in the rear...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 10-04-2011, 07:12 AM   #5
pickle311's Avatar
Trader Rating: 31 (100%+)
What track are you running at? Aren't you from Texas?
With that much camber, it sounds like you are running on a high bite track. If that's the case and your tires are wearing close to the middle, that leads me to believe a few things are taking place. Mainly, it sounds like too much body roll.
This could be caused by the suspension being too soft for the track, sway bars too soft, ride height too high are the first things that come to mind.
For the track I think you are running at, I use a very stiff and low suspension setup and don't have to run more that -2 camber.
Thanks to my sponsors and friends
RC America l Xray l Hudy | Pro-Line |KO Propo | Avid | VP Powermaster
pickle311 is offline   Reply With Quote
Old 10-04-2011, 07:06 PM   #6
JsK
JsK's Avatar
Unless your extremely smooth on the throttle all tires(1/8 scale offroad)
are going to wear the center out. Its centrifigul force causing them to expand and run on just the center tread during acceleration. If the fronts are wearing badly down the center or losing pins try a higher weight center diff oil.
JsK is offline   Reply With Quote
Old 10-04-2011, 07:55 PM   #7
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
I will say a lot of my side pins do wear some - from sliding the buggy around. Of course it all depends on setup, tires, track, and driving style. But I agree: centers wear the fastest.
To op: Are you running -4.5/-3.5 on the Xray or D8? That's A LOT of camber.
Rsickles is offline   Reply With Quote
Old 10-04-2011, 08:39 PM   #8
rfleck's Avatar
Trader Rating: 58 (100%+)
When I setup using the Hudy, my camber is about 2 degrees more than when using an RPM camber gauge. For example -5 with Hudy equals -3 using the camber gauge.
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 10-04-2011, 09:47 PM   #9
That is what I see too. Knew I wasnt crazy haha. So i think im going -5 rear -4 front, high speed turns this weekend. Dont wanna traction roll.
Old 10-07-2011, 06:14 AM   #10
Diff Balls's Avatar
Trader Rating: 38 (100%+)
I see the same thing......I've been trying to figure it out, I think it may be from all the weight of the car being on the slim gauges and it pushes it out more at the bottom versus what a tire would do therefore making it have more negative camber while the gauges are attached.
Anyone else have any thoughts???
Diff Balls is offline   Reply With Quote
Old 10-08-2011, 09:26 PM   #11
j_blaze14's Avatar
Trader Rating: 34 (100%+)
roll center, drop the inner camber link in the rear.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Traction vs. Weight jasonwipf Electric Off-Road 33 08-02-2010 07:22 AM
G.L.A.R.C.R.C.19TH ANNUAL TOYS FOR TOTS gwilli2001us Nitro On-Road 166 01-24-2009 09:54 PM
