Old 09-08-2011, 09:10 AM   #1
Trader Rating: 66 (100%+)
Default What to do for more fuel capacity?
I'm considering adding external fuel filters (maybee even 2) just to get more milage between fuel ups. Any sugestions on which filters hold the most and how to plum in 2?
If you can't race it or sleep with it, it ain't worth having!
Gwoodrc is offline   Reply With Quote
Old 09-08-2011, 09:28 AM   #2
Trader Rating: 50 (100%+)
You can add fuel filters (without the filters) and fuel line for more capacity.
You can also heat up the sides of your tank and enlarge it by expanding/pushing the sides out from the inside. Kinda of a PITA but works.
You can also get better fuel mileage by taming down your throttle finger
Pre-Loaded
ForwardBite is offline   Reply With Quote
Old 09-08-2011, 04:29 PM   #3
Slider30250's Avatar
Having an engine that is good on fuel is the number one thing to do. Extra fuel line,fuel filters, or taking the restrictor out of your fuel tank don't really give you any significant increase in runtime, maybe a minute.
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 09-08-2011, 04:56 PM   #4
Yeah but if you have a $200 motor, all those things are better options than buying a $400 motor and playing with an assortment of $100 pipes
And even then you may only pick up a minute after spending hundreds of dollars
Mark _australia is offline   Reply With Quote
Old 09-08-2011, 05:22 PM   #5
True, but I have a feeling that Gwoodrc might only have a 7 min motor hence the reason he's looking for some advice on gaining runtime.
Old 09-08-2011, 10:37 PM   #6
Yes I had a Ninja (last years, not the new one) in a durango and our track requires alot of wide open throttle so its hard to get fuel milage. The motor was about on its last leg anyway, so after tonights race I decided to retire it for a freshen up with a speed piston and sleeve hopefuly will make it more efeciant. But I also know that the Durango doesnt have a large tank like some other manufactures that you can take the spacer out of for 15-20 min club races where nobodies checking tanks, so I was looking for as much extra as I could find to possibly add a minute of runtime. But now I am gonna put my other motor on (werks B6) that I know gets better milage while i'm freshening up the Ninja!
Old 09-09-2011, 12:35 AM   #7
merdith6's Avatar
Default tough question....
I've had most Novarossi engines and every one gets the same mileage. It must be more to do with my driving style and the car, even between my two cars i don't notice any difference, so you could limit the throttle travel a little bit, or run the engine a bit leaner, try a different fuel, but that's all I can think of. even pipes don't really make much difference, but most swear by the 9901 on a nova. Monty's extreme x7 seemed to do pretty good on fuel, it's cool to see such a powerhouse of an engine avoid using more fuel...
Adding too much fuel line and extra filters seems to only cause tuning issues, but hey, that big ol kyosho filter can't hurt runtime...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 09-09-2011, 06:25 AM   #8
Gwoodrc -> No 125cc max capacity rule at your track?
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 09-09-2011, 09:39 AM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
Many tanks are under capacity. I add fuel filters to get the tank and lint to capacity. No arisen makes a large fuel filter that adds 2.3cc. My fav was the odonnel filters but they don't make them anymore.
Old 09-09-2011, 09:51 AM   #10
Ian b's Avatar
try putting a smaller venturi in the carb .its the first thing i would do
Ian b is offline   Reply With Quote
Old 09-09-2011, 04:05 PM   #11
Trugsta's Avatar
Send a message via MSN to Trugsta
Yup ^^.
+Gass cooler.
Longer fule line.or add filters as you mentioned.
Tuning.
Clutch setup.
and an easy throttle finger...
1+ minute of extra run time is pretty much equal to an extra lap on the track.
Proud Member of S.C.O.R.C.
Losi 8T2- Novarossi P5/Novarossi and GRP pipes.
spektrum DX3S. SAVOX servos. "Race till it MHZ"
A huge thanks to.
www.motorsaver.com (the absolute best filters and savers on the plannet).
Trugsta is offline   Reply With Quote
Old 11-09-2011, 11:10 AM   #12
electric racer's Avatar
Too many fuel filters can restrict fuel flow, I would just suggest tapping the throttle
XTM......... Yes XTM, they DO exist, and they're brilliant!!!!!!
electric racer is offline   Reply With Quote
Old 11-09-2011, 03:02 PM   #13
Rsickles's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to Rsickles
Was wondering about this too.
You said you are in a Durango, which is probably under the 125cc? First thing I would do is measure out 125cc of nitro and dump it into your tank (empty) and see where you're at.
That said, nothing will beat fuel mileage like properly tuning your engine.
Rsickles is offline   Reply With Quote
Is it time again for 1/10th scale pan cars? outrunner25 Electric On-Road 325 10-21-2012 07:00 AM
Upgrading your Monster to Plastic or Aluminum? nitrokings Monster Trucks 8 12-30-2010 09:34 PM
Radio Question- What is best, 3pk etc.. Ryan41 Nitro On-Road 53 06-01-2007 11:30 PM
GOOD FUEL scarlet Nitro On-Road 147 03-10-2007 08:41 AM
