Wider rear tires on 1/8 scale Buggy
What is the reason that 1/8 scale Buggies don't use wider rear tires? Would the added grip factor not be worth the extra amount of slight drag and weight? 1/10th scale buggies have always had wider rears.
I think it would look very cool as instead of having the same width all around.
Just something I always wondered, has anyone tried to see a performance difference?
just a thought, may be way off.. but the added rotation weight would make the drive train unstable, having heavier rear wheels than front wheels. and the front end would be working harder than the rear end. 1/10th off roads are mostly only rwd therefore this issue does not arise...
I hear you but, if rotational mass would make the drive train unstable then all the 4WD buggies (B44, D4, Durango DEX410R, Tamiya TRF, Schumacher CAT XXX-4) would all suffer from this. I had the D4 and it ran fine.
I still use V3 proline tires, infact, I just finished gluing a set of revolvers. I usually find them very cheap on eBay. I use them on the rear of my 811.
I did notice a slight increase in rear traction and didnt feel like the drivetrain was unstable at all.
I still use them because I actually get them cheaper than regular tires lol
i stand corrected
