Old 08-31-2011, 01:17 AM   #31
rc skyline's Avatar
Default Metho
Anyone using or ever tried Metholated spirits?
Dave
MUGEN MBX7R & MBX6TR
FUSION X ENGINES By Novarossi
BUKU Power Clutch
MECCAMO FUEL - BETA Tires
www.fusionxengines.com.au
rc skyline is offline   Reply With Quote
Old 08-31-2011, 01:33 AM   #32
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
I use acetone..you don't even need to scuff anything up..just put it on a rag, wipe and glue.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 08-31-2011, 02:24 AM   #33
Dave
Methylated spirits is the same thing. Known as denatured alcohol in the US.
http://en.wikipedia.org/wiki/Denatured_alcohol
John. is offline   Reply With Quote
Old 08-31-2011, 04:02 AM   #34
rc skyline's Avatar
Wow well there you go.. and here i am allways thinking gee that denentured alcohol the yanks allways talk about must be good stuff
Im guessing it would be one of the cheaper things to use also.. Cool,
Dave
BUKU Power Clutch
Old 08-31-2011, 04:22 AM   #35
morgoth's Avatar
I always use AKA rims and the is prepared with something so never scuff the rims or use alcohol on them.
The only thing I do is scuff the bead of the tire a little and then clean it with denatured alcohol.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 08-31-2011, 05:06 AM   #36
offr0aden's Avatar
I use nail polish remover at home - and at the track I used some Windex on an tire coming off a fellows rim and it worked great. Simple green also works well (I was out of simple green at the time). I bake my old tires off @ 400* for 10 minutes a side (To save the foams) then use a sanding barrel to prep the surfaces.
So far so good!!!
- Team -
"High Speed and Clean"
offr0aden is offline   Reply With Quote
Old 08-31-2011, 10:58 AM   #37
rdeppen's Avatar
rubbing alcohol and fresh locktite glue from home depot stored in my fridge.
I've seen more problems come from glue being left in a tool box in a hot garage or trunk then mold release agents not being cleaned off. Never trust old glue and store it in a cooler at the track.
I also refuse to buy ANY tires that are in the old plastic clear bags cough (old jconcpets stock) cough.
Those are the only tires that ALWAYS come unglued on me no matter how much I clean the damn bead SMH. Those things must be sanded or they ARE coming off. All the new stuff from them in the resealable bags are fine thou.
rdeppen is offline   Reply With Quote
