Old 08-26-2011, 06:05 PM   #16
I scuff the wheel and tire with a dremel sanding drum, then clean with denatured alcohol. I've never had any problems with this method.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 08-26-2011, 08:13 PM   #17
Doitinthedirt's Avatar
I heard nail polish remover works.....Im yet to try it but my friend said it works good
Doitinthedirt is offline   Reply With Quote
Old 08-26-2011, 08:17 PM   #18
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Brake Cleaner
~Brad Shearer~
Team Associated ~ Motiv ~ JConcepts ~ Team Gravity RC ~ MIP ~ 92zerodesigns.com ~ Shearer-It Paint Designs ~ LiveTime Scoring ~ LiveRC.com
Brad S. is offline   Reply With Quote
Old 08-26-2011, 09:02 PM   #19
I used a Dremel sanding wheel on both the wheel and the tire and then use the Lysol wipes for the kitchen to wipe everything off. Works like a charm
Revooooooo is offline   Reply With Quote
Old 08-26-2011, 10:42 PM   #20
Tony Newland's Avatar
Trader Rating: 50 (100%+)
windex and a CLEAN towel... not the oily one you just used to rebuild your diffs and shocks lol
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 08-26-2011, 11:15 PM   #21
ronsand's Avatar
Thumbs up
I scuff the rims and tires with abrasive sanding paper or a sanding drum. Before gluing, I wipe both with acetone.
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 08-27-2011, 12:47 AM   #22
shanef's Avatar
Trader Rating: 38 (100%+)
Loctite 406, it's all you need
shanef is offline   Reply With Quote
Old 08-27-2011, 01:02 AM   #23
This all I use, its the best glue I found period! tried all the hobby shop stuff some better then others, this stuff is the best. I don't prep the surfaces anymore.
http://www.loctiteproducts.com/p/sg_...ofessional.htm
you can get it anywhere, home depot, lowes, walmart, etc.
purple rides is offline   Reply With Quote
Old 08-28-2011, 08:53 AM   #24
HuntersDad's Avatar
Trader Rating: 38 (95%+)
if you use brake cleaner be sure to use non-chlorinated.
TLR - JConcepts - Avid - VP Fuel - OS Speed
HuntersDad is offline   Reply With Quote
Old 08-28-2011, 11:23 AM   #25
PTP Racing's Avatar
I think the carb cleaner is your problem. Like someone already mentioned carbon cleaner also has some oil in it to lubricate the parts of the carb. Brake parts cleaner is specifically made to leave no residue so that the brake parts work properly.
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 08-28-2011, 01:49 PM   #26
lee_double2000's Avatar
Trader Rating: 45 (100%+)
Man every method on this thread sounds great. I wish I had all this info when I first started racing. LOL
lee_double2000 is offline   Reply With Quote
Old 08-29-2011, 09:23 AM   #27
Denatured Alcohol + the above glue is what you want to use.
Losi 8ight T 2.0 - Mugen Ninja
Mugen Eco - Tekin 1900KV RX8
Byrons 30%
Spektrum
Proline/J Concepts/AKA
bacchus is offline   Reply With Quote
Old 08-29-2011, 05:00 PM   #28
.rc_racer's Avatar
LMAO now thats a classic one
Sponsored by----Jesus....My job...And my wife...
Losi 8E 2.0...Losi 8T 2.0...Losi 8 2.0...Losi 22...
.rc_racer is offline   Reply With Quote
Old 08-30-2011, 12:18 PM   #29
mattozx6rr's Avatar
Trader Rating: 15 (100%+)
Rubbing alcohol and locktite glue. Never had a tire give yet.
Matt
1 X MBX6T plus 21-4c
Twisted Bones R/C apparel
mattozx6rr is offline   Reply With Quote
Old 08-30-2011, 09:52 PM   #30
razo125's Avatar
+1
I used to use denatured alcohol religiously but I tried window cleaner and noticed an improvement. I got this advice several times from very experienced racers. They said make sure use window cleaner with amonia. it's the ammonia that seems to make a difference.
spray the whole tire even the pins. it removes the mold release compound and makes them grip better
__________________________________________________________________
Thanks Red Rock Hobbies for all the support. www.redrockhobbies.com
___________________________________________________________________
razo125 is offline   Reply With Quote
