Old 08-22-2011, 04:02 PM   #1
easydoesit's Avatar
Default Dirt oval Late Model help
I'm running a 1/8 buggy chassis with LM body on a oval that hard packed clay and very dusty/loose at times. Any suggestions on diff oil setup and spring rate? I'm currently running medium springs in the front and soft white springs in the rear. Diffs are 120k Frint/50k Center/7k Rear. I just started running this LM and its very unpredictable and loose. The rear acts like its doing the steering. I can control it fine at slow pace but can't put down any power like my other cars I race. Any suggestions to get me in the ballpark greatly appreciated.
easydoesit is offline   Reply With Quote
Old 08-31-2011, 01:24 PM   #2
toobad4u's Avatar
Trader Rating: 93 (100%+)
When I ran a RC8 1/8th dirt oval I ran 120k frt, 300 center, 7-15k on rear. You can also vary the spring and shock oils and tighten and loosen the springs on the shocks to help. Try dirtoval.com for some more helpful info.
Stephen
Mihabi RC Your Hometown Hobby Shop.
(850) 914-2815
toobad4u is offline   Reply With Quote
Old 08-31-2011, 03:43 PM   #3
Jeauxkor's Avatar
Trader Rating: 29 (100%+)
How much toe out you running up front? And how much toe in in the rear?
Jeauxkor is offline   Reply With Quote
Old 09-01-2011, 03:54 PM   #4
Trader Rating: 45 (100%+)
try 15-15-5 in diffs ,that should tame it down !
rc racer 103 is offline   Reply With Quote
1/8 DIRT OVAL LATE MODEL BUCKSHOT Oval, Larger Scales and More 39 07-11-2009 04:45 AM
1/8th scale Dirt Oval Late Model bige Oval, Larger Scales and More 15 02-18-2009 05:43 PM
OFNA Ultra GTP Dirt Oval Set-up HELP!?? crankerUP Oval, Larger Scales and More 10 07-14-2008 06:30 AM
