Old 08-19-2011, 11:19 AM   #1
Default Need tire suggestions!
Hey Guys,
I need a tire that works well on a very dry, dusty, and very slippery track. What would you guys suggest for me to try? Probably something that would oversteer, I'm getting a lot of push (understeer) both on and off throttle.
Thanks in Advance
Brian
Mbx7R|Alpha Dragon A830/2107 Lutz MBX7|Alpha A852/2107 Lutz
MBX7T|Alpha A352 .23/2090,MBX6|Alpha A872/0801, MBX6T|Alpha A352 .23/2090
SCTE|Tenshock 4k/Hobbywing, B4.15|Speed Passion 5.5t
PowerMaster|AKA|RadioPost|Buku
Can't find the limit until you cross it!
Crash Test Dumy is offline   Reply With Quote
Old 08-19-2011, 11:21 AM   #2
Trader Rating: 163 (100%+)
buggy or truggy?
cjm1126 is offline   Reply With Quote
Old 08-19-2011, 11:36 AM   #3
Truggy Sig says MBX-6T
Old 08-19-2011, 12:13 PM   #4
Danny B's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to Danny B
Honestly, in very dry, loose conditions as you described, tires are probably not the biggest issue. No tire is going to magically give you grip when there is no grip to be had. Depending on wear, you want to run the softest tire you can get away with. Thread pattern that would probably best would be a Cityblock, caliper or digit type thread.
But the biggest thing, is slow down. Slow is fast, buzzing the tires and sliding into and out of the corners is nothing but a waste of time and equipment. Keep the truck straight and square on the track and drive smooth on the throttle and braking, I guarentee that will be faster and more consistent.
Outside of driving and tires. drop your center diff fluid 2-3K maybe more depending on what you have now. soften up the clutch springs and possible even consider carbon shoes instead of Alum.
Tekno RC
Pro-Line Racing Tires, Futaba,
O.S., Hobbico, 92Zero Designs
Danny B R/C Products,
LRT Raceway, Evansdale, IA
Danny B is offline   Reply With Quote
Old 08-19-2011, 01:22 PM   #5
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Nailed it... Coming up to a corner and riding the pipe is much faster then throwing it and drifting. Not only is that killing the tires and putting stress on the car and clutches/engine but its slowing u down. Thats why drifting is a whole diffrent motor sport then rally cross. Odds are your not getting push ur just coming up to the corner to fast and not slowing down and using braks. For tires try a stacked pattern like Danny said. Caliber, Suburbs, City-Block, etc. If you stay in groove where its not loose then i would say Impakts, Gridiron, etc.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 08-19-2011, 02:24 PM   #6
I totally understand what you guys are saying and I agree. I guess I should have said what is the tire best for traction in slippery powder?
I just need a point in the right direction, I don't want to spend $75 on a set of tires that will do me no good!
I just want to get some suggestions, so I can buy a set and try, without wasting my money.
I've been looking at I-Beams and Bowties, but there must be other choices. And why do manufactures have different compound rating codes!
What's wrong with soft med and hard? And why aren't all the buggy tread patterns available for truggy? I did hear something about ROAR is going to make some decision soon affecting this.
Anyway, sorry for my rant!
Cheers
Brian
Old 08-19-2011, 02:28 PM   #7
R/C Lidz's Avatar
Trader Rating: 53 (100%+)
Send a message via MSN to R/C Lidz
Honestly, in very dry, loose conditions as you described, tires are probably not the biggest issue. No tire is going to magically give you grip when there is no grip to be had. Depending on wear, you want to run the softest tire you can get away with. Thread pattern that would probably best would be a AKA Cityblock, Proline caliper or Losi digit type thread.
also, if you are pushing, having a small pin tire above up front and something with more forward bite like a Ibeam or bowtie in the rear get the truck to rotate.
Josh Langness
RC8T/ OS Speed/ 2060
RC8/ OS Speed/ 2060
FTGT/ MT12
BLitZ/ Castle SCT
R/C Lidz is offline   Reply With Quote
Old 08-19-2011, 04:25 PM   #8
Yeah, I saw someone selling on Ebay saying he ran city blocks up front and I-beams in the rear. I thought I would try something like that.
Old 08-19-2011, 04:28 PM   #9
rider313's Avatar
Trader Rating: 94 (100%+)
if temps arent to high go super softs to try and get the treads to stick to the track. Like stated a Multi pin tire is going to be key.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 08-19-2011, 04:37 PM   #10
The track is sooooo dusty, it's like driving on an inch of flour! I thought if I could get the best tire for that and then learn to drive those when the track is still moist and tacky.
Anyone heard of spraying sugar water on the track? I hear it turns to rock candy eventually and the need for water is drastically reduced, but wears out tires faster.
Cheers
Brian
Old 08-19-2011, 05:00 PM   #11
JsK
JsK's Avatar
Hard pack with a layer of loose dirt/dust - M3 Caliber.
If the track is loose all the way down or the dirt/dust
layer is really thick then I-beams in supersoft.
I would avoid the City-Beam combo unless the track has
some hardpack under the loose layer.
JsK is offline   Reply With Quote
Old 08-19-2011, 05:12 PM   #12
B-ray95's Avatar
Cheers
Brian
Well all my local tracks are pretty much all Dry,dusty etc.. Our best tire to go are I-beams and Bowties,get a set of I-beams in soft I'm still on my first set. and They'll last much longer than Cityblocks Calibers etc.
Now for ur question why there are not as many tires for truggys than buggies is because not every tire that works with buggy works as good for truggy
Hope I helped
Brian
Agama A8 Evo/GO-Engines GX-7r/AKA Tires/Sav÷x/Team Saxo fuel/Spektrum DSM
Team Associated B4 FT / Nosram/Pro-line Tires/Graupner/Nosram X-treme/Spektrum DSM
Team Associated RC10r5/LRP/CRC Tires/Futaba/Nosram X-treme/Spektrum DSM
Thanks to my Sponsor Mike @ Sonic Raceway Boom na Boom Pasig City and ofcourse my Mom :)
B-ray95 is offline   Reply With Quote
Old 08-19-2011, 09:08 PM   #13
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
Ibeams, Caliber, Crimefighter, Losi Digits, JC CrossHairs work good on loomy condition
I run Caliber and Ibeams
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 08-19-2011, 10:28 PM   #14
tc5 man's Avatar
on dry and dusty dirt ive had good results with "soft I-Beams" on truggy and the jconcepts crosshairs soft work decent on dry dusty dirt but work better in the loamy condictions than the I-Beams if you ask me.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 08-20-2011, 12:33 AM   #15
Ambros303's Avatar
Loose dust an inch thick? You need a tire with bigger lugs to dig in the dust deeper:
AKA I-beams, JC crosshairs, PL crimefighter, PL bow tie, VTEC Kamikaze, etc.
Use soft compound.
Kyosho ST-RR Evo-ed // Sirio // Hitec // Sanwa
Kyosho MP9 TKI2 WC // Sirio // Savox // Sanwa
Ambros303 is offline   Reply With Quote
New 1/8 or 1/10 4wd buggy setup; need your suggestions! 00Aron Electric Off-Road 7 07-10-2011 03:34 AM
Need tire suggestions for SC10 gorilladiver Electric Off-Road 20 01-25-2010 06:44 AM
need some suggestions reptilesnr/c Monster Trucks 22 01-15-2007 06:02 PM
Got an Xray. Now, what? (pinion/spur combination/tire suggestions) Tom G Electric On-Road 8 06-12-2004 04:04 AM
