Do you guys slip shock boots over shock ends 8b2.0?
I just got a 8b 2.0 recently and I went to put shock boots on but not sure if I should trim front and then let them both front and rear hang free or slip over shock ends? I noticed they kind of suck up to shafts if you slip them over shock ends but not sure which is correct. Thanks!
Suspended
use the serpent ones they just ride on the shaft and will never tear unless the air comprosir does it
I run the losi boots but i cut them just above the spring retainer. i have 3 gallons on the original set with no tears. My seals still last along time.
