Old 08-13-2011, 07:19 AM   #1
Default Adjusting suspension rebound
Can you guys help me get my rc8b suspension to rebound. I have moved the shocks to the lowest setting, screwed the stop screws all the way in.and tightened the springs all the way on the shocks.also tightened the sway bar all the way. If you push car down the suspension sags and stays there. I want it to bounce so to speak. Thank you
Burgrc8b is offline   Reply With Quote
Old 08-13-2011, 07:22 AM   #2
adrictan's Avatar
Take the shocks off yr car. Remove the springs from the shocks. Try pushing the shock shaft upwards. Do you get any rebound?
Sponsors: T-Bone Racing, Misfit Design Group, Maclan Racing, IB Prostart, PTRC Oils, Vision Racing Products, SRT Servo, Boca Bearing, Soar Seiki.
Soar Enquiries: adric.tan@soarseiki.com
adrictan is offline   Reply With Quote
Old 08-13-2011, 07:23 AM   #3
What weight shock oil are you using?
Losi Jrx-T
Losi xxx-nt Sport
HPI Blitz
TLR 22 3.0
Otis_Losi is offline   Reply With Quote
Old 08-13-2011, 07:31 AM   #4
The car is brand new, bout a month old. Took shocks off to make sure they were full. And they were. Yes the did rebound. I'm using 25wt shock oil, which is what came with the car. When pushing car down it like frowns, maybe like the suspension pins are to tight. Is this possible?
Old 08-13-2011, 07:32 AM   #5
Sorry it groans not frowns
Old 08-13-2011, 07:34 AM   #6
adrictan's Avatar
If the shocks can rebound after being taken off the car, it's most likely the car that has a problem. Like u said, the hinge pins. Check for any binding. 25wt also seems a little thin.
Old 08-13-2011, 07:34 AM   #7
teamlosi906's Avatar
Trader Rating: 235 (100%+)
Take the shocks off and make sure everything is moving nice and easy,and then make sure the shocks are also when mounted.
Serpent S11T Losi ten scte Houston Tuned Team Toronero 2084 ss, plus 4 team 9901 ss pipe Hitech servos Proline tires SPONSORS T@T MOTOR SPORTS AND SKIDOO racing TEAM TERRIBLES,And finally my wallet.In Memory of my Boy Brian!
teamlosi906 is offline   Reply With Quote
Old 08-13-2011, 07:38 AM   #8
Give it a shot. Should I lightly sand the holes and pins and then lube them ?
What is a good medium shock oil? Also what is a good medium diff fluid. Cause if the shock oil is thin then the diff fluid prob is too?
Thanks as always boys
Old 08-13-2011, 08:12 AM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
Without the shocks on tue suspension arms should move up and down freely. If not most likely the holes in the arms where the hinge pins go need to be framed out. Buy an arm reamer that is the correct size and run it through the holes until the pins rotate smoothly. If you want to lubricate them you need to use a dry type lube.
Measure the diameter of your hinge pins and then but the correct size arm reamer. Here's a link to one that's for 3.5mm
http://www.amainhobbies.com/product_...rm-Reamer-35mm
Old 08-13-2011, 08:20 AM   #10
ScottyM's Avatar
Trader Rating: 27 (100%+)
If the car is groaning / squeeking what ever you want to call it then the plastic needs reemed out. Full of dust and dirt keeping things from working like it should.. I was amazed the first time I reemed the hole my hinge pins went in.. Car was like night and day from one qaulifier to the next..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 08-13-2011, 08:28 AM   #11
johnny t's Avatar
+ YouTube Video
johnny t is offline   Reply With Quote
Old 08-13-2011, 03:55 PM   #12
JsK
JsK's Avatar
You may have the shocks on backwards. If the caps are on the mount
the wrong way they will rub the towers. Take the upper mount off rotate
the cap 180deg then remount them. Bleed holes face inwards toward
the towers.
JsK is offline   Reply With Quote
Old 08-13-2011, 04:29 PM   #13
neobart's Avatar
I noticed you said you tightened the sway bars. They need to be loose.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 08-13-2011, 05:14 PM   #14
It was the shock mount. I had the bushings facing out. It has to be inside. Like nite and day now. Thank you , thank you, thank you
Old 08-13-2011, 05:25 PM   #15
JsK
JsK's Avatar
Ask me how I knew
Hot Bodies Cyclone Frank McKinney Electric On-Road 19762 07-26-2017 10:42 PM
Robitronics Scalpel 1/18th Pan Car? oXYnary Micro and Mini Scales 1271 04-20-2016 08:10 AM
E-Revo Suspension help!!!!! XxE-ReVoRaCeRxX Electric Off-Road 15 07-15-2010 04:24 AM
