Old 08-04-2011, 04:23 PM   #1
8T
8T's Avatar
Default Roll center
I was reading about roll center in an other thread. I like to know what it is, how to change it, and what the changes will do. I have a Losi 8T 2.0 and an 8B 2.0 if it matters!
tia
8T is offline   Reply With Quote
Old 08-04-2011, 04:37 PM   #2
Slider30250's Avatar
tia
From the Hudy off road and truggy setup book.
A “roll center” is a theoretical point around which the chassis rolls, and is determined
by the design of the suspension. Front and rear suspensions normally have different roll
centers. The “roll axis” is the imaginary line between the front and rear roll centers. The
amount that a chassis rolls in a corner depends on the position of the roll axis relative
to the car’s center-of-gravity (CG). The closer the roll axis is to the center of gravity, the
less the chassis will roll in a corner. A lower roll center will generally produce more grip
due to the chassis rolling, and the outer wheel “digging in” more. Roll-centers have an
immediate effect on a car’s handling, whereas anti-roll bars, shocks and springs require
the car to roll before they produce an effect.
Roll center is determined by the car’s suspension geometry. Each end of the car has its
own roll center, determined by the suspension geometry at that end of the car.
Depending on the car, front and rear roll center may be adjusted by raising or lowering a
variety of different pivot points of the suspension arms & blocks, such as the following:
• inner upper pin/link
• outer upper pin/link
• inner lower pin
• outer lower pin
For information on adjusting roll center on cars with other adjustment possibilities
(for example, outer lower pins) please refer to the manufacturer’s original detailed
documentation.
FRONT ROLL CENTER
Typically on off-road cars front roll center is adjusted using
the front upper camber link inner mounting position on the front shock tower. Those
same holes on the front shock tower may also be used to adjust camber rise. For more
information, see the section on Camber & Camber Rise.
For information on adjusting front roll center on cars with other adjustment possibilities
(for example, the outer lower pin) please refer to the manufacturer’s original detailed
documentation.
EFFECTS OF FRONT ROLL CENTER ADJUSTMENT
FRONT UPPER CAMBER LINK -
SHOCKTOWER
EFFECT ON FRONT ROLL CENTER
Upper holes (lower roll center) • Increases steering into corner
• Car is more responsive
Lower holes (higher roll center)
• Decreases steering into corner
• Car is less responsive
• Use in high-grip conditions
REAR ROLL CENTER
Typically on off-road cars rear roll center is adjusted using
the rear upper camber link inner mounting position on the rear shock tower. Those
same holes on the rear shock tower may also be used to adjust camber rise. For more
For information on adjusting rear roll center on cars with other adjustment possibilities
documentation.
EFFECTS OF REAR ROLL CENTER ADJUSTMENT
REAR ROLL CENTER CHARACTERISTICS
Higher
• Increases on-power traction
• Use to avoid traction rolling at corner entry
• Use under low-traction conditions
Lower
• Decreases rear traction into corner
• Use to avoid traction rolling mid-corner and corner exit
REAR UPPER CAMBER LINK -
LENGTH
CHARACTERISTICS
Shorter link (outer hole on tower and/
or inner hole on hub)
• Increases steering and decreases
stability into corner
• Increases on-power traction slightly
Longer link (inner hole on tower and/or
outer hole on hub)
• Decreases rear camber gain
• Increases stability
• Slows down the car‘s responsiveness
Anyone can crash, I crash with style
Mugen MBX6R/Airtronics M11X/Ninja Engines/Sidewinder Fuel/EB Mods
Slider30250 is offline   Reply With Quote
Old 08-04-2011, 04:47 PM   #3
8T
8T's Avatar
• inner lower pin
• outer lower pin
documentation.
FRONT ROLL CENTER
documentation.
SHOCKTOWER
REAR ROLL CENTER
documentation.
Higher
Lower
LENGTH
CHARACTERISTICS
outer hole on hub)
Awsome, thanks!
Old 08-04-2011, 05:12 PM   #4
Your welcome.
Lets discuss roll center in offroad. Cpt.America Electric Off-Road 35 11-24-2015 12:55 AM
Roll Center WisRacr1 Electric On-Road 35 01-07-2012 11:11 PM
Roll Center Program? Speedie Electric On-Road 10 04-05-2007 02:26 PM
Have you worked out your Roll Center? BJ Electric On-Road 25 05-02-2006 04:48 PM
Roll Center question ScottyP Australian Racing 48 02-08-2003 04:00 AM
