Old 08-03-2011, 05:53 AM   #16
I would have thought first thing to try is pliers?
Then heat with soldering iron on screw, with pliers.
Then cutting a slot in it
Mark _australia is offline   Reply With Quote
Old 08-03-2011, 11:02 AM   #17
shesha's Avatar
Send a message via MSN to shesha
yup its pretty much like powdered metal shaving most of the time it works, if all else fails then revert to the dremeling, having several options before hand is better then "we be fuc***" afterwards and scratching your head.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 08-03-2011, 11:23 AM   #18
morgoth's Avatar
After you got it out, try to fit a head cap screw. This allows you to use a bigger hex (usually 2.5mm instead of 2.0mm) and you can use pliers if the screw is stuck. I think I'll also do that from now on.
And if the cap head screw is close to the tank, glue a little piece of metal onto the tank.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 08-03-2011, 11:49 AM   #19
This is funny, Try this and Try that.
15 seconds with a dremel. A tool all RC hobbiest should have.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 08-03-2011, 02:36 PM   #20
savannahmick's Avatar
Default Well I am going to get off but after points race Saturday!
I will dremel slot and remove this weekend but I want to run race first my shoes are good I has just trying to clean front bearing and scuff my bell (HAHA) but since I stripped screw I will run race first due to my luck and finup something I can't fix now. Does leaky front bearing usually mean the bearing going bad the motor is old(6 gallons jx.21) but runs good but does have two stage idle and lately it has dropped more and had to adjust to correct idle. Also I have already shoe gooed a piece of thick lexan to tank. Thanks for all the info/help!
Kyosho TKI3/ Fusion X5LFM tuned by H.E.S / Fusion X3LFM tuned by H.E.S./ Nova 9886ss/ RB 2045/ Savox 1271+1268/Schumacher KR/ Viper VTXr10/ Viper VST 7.5/ Savoy 1267/ Futuba 3pks/ Spectrum 2.4 Mod/ Spectrum Pro 3001/ Spectrum 3000
savannahmick is offline   Reply With Quote
Old 08-04-2011, 06:02 PM   #21
For most stripped screws I use center punch. Harbor Freight has em pretty cheap.
Philhurdraceway.com
drdsanders is offline   Reply With Quote
Old 08-05-2011, 01:51 PM   #22
steve307b's Avatar
Trader Rating: 23 (100%+)
Plus 1......dremel a slot & its done. I even keep using the slotted screws on the Losi clutch bells. They last longer than the hex head.
8ight-T 3.0 **FX Royal Engine** 2013- Savox 1267/Hitec 7950
Henchman racing
DX4R
steve307b is offline   Reply With Quote
