Old 08-02-2011, 04:05 PM   #31
Suspended
Trader Rating: 202 (96%+)
Originally Posted by warnked View Post
$1 bearings ?! when it comes to bearings, you get what you pay for.
thats the way it normally works, you buy it and then you get it, if you dont you have been ripped off!
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 08-02-2011, 04:21 PM   #32
ghost68's Avatar
Ill pit my $.85 TKO bearings against anything you might have... All you are paying for is brand name otherwise...
-Dustin Bullard
***HoBao Hyper Star/JL .21PRO/2047/Savox/AKA***
I would like to say Thanks to my sponsors: Team OFNA and Sidewinder Fuel
ghost68 is offline   Reply With Quote
Old 08-02-2011, 04:23 PM   #33
Suspended
exactly
Old 08-02-2011, 07:21 PM   #34
jk1152's Avatar
Seems most of the post here are talking about clutch bearings. I was more wondering about all the other bearings in your car. I change clutch bearings all the time. And as someone here said, blow the grease out of the one that is next to your shoes and use the factory grease on the front bearing of the bell. Moving on.... to see more about every bearing except clutch bearings. Example diff, bulkhead, and hub bearings.
jk1152 is offline   Reply With Quote
Old 08-04-2011, 10:27 AM   #35
warnked's Avatar
Yeah i dont want to pay for a brand name, but i dont want to pay for a bearing that has been made in a bootleg factory with dirt floors in china either. It happens.
P.S. Your paying for a name any time you buy repackaged bearings from a Hobby store or bearings categorized as "RC". Go straight to the manufacturer/distributor...Koyo and Micro Miniature. (just make sure you know the specs and ratings). Whatever, im no expert.
AE B4.1 Worlds, Losi XXX-T CR, Tamiya F104, Jammin x1x, HPI rs4 evo+
warnked is offline   Reply With Quote
Old 08-04-2011, 12:15 PM   #36
what bearing oil you guys use? I use some high temp grease that comes in that huge tube. The viscosity is thick, but it frees up once it heats up.
Aside from the CB bearing, I replace the rear hub bearing more often. Seems like they take the most beating.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 08-04-2011, 12:18 PM   #37
ghost68's Avatar
SpeedX works fantastic for me.
-Dustin Bullard
Old 08-04-2011, 12:20 PM   #38
ghost68's Avatar
TKO's specialty is 1:1 racing (Stock Cars, Drag Cars etc...) bearings... No dirt floor manufacturing there...
-Dustin Bullard
Old 08-04-2011, 12:45 PM   #39
on another note, are ceramic bearings worth it? they are about $4 ea.
TLR 22 3.0
Apex RC Proshop
Old 08-04-2011, 03:31 PM   #40
Jaz240's Avatar
Trader Rating: 52 (100%+)
I use acer racing Sin Lube. You can put a drop right on the rubber seal and it will soak into the bearing
They last longer, dont heat up as much, but need to serviced. If you dont open them and clean them its a waste of the extra money
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 08-04-2011, 03:37 PM   #41
Suspended
ceramic bearing dont last as long, and dont like dirt at all. stick with the 1.00 bearings
