Old 08-01-2011, 10:49 PM   #16
How do you oil a CB bearing exactly? And what oil? (will ARO work?)
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
Old 08-02-2011, 12:41 AM   #17
morgoth's Avatar
I drive at least 2-3 gallon with my bearing. I only toss them out when they feel gritty or very dry. Once you cleaned your bearings, they don't seal that good anymore and the spilled oil attracks dirt.
The only bearings that I change frequently are my clutch bearing. A new set for the qualifiers, a new set for the finals and sometimes another new set if I have to run more then 2-3 finals.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 08-02-2011, 04:39 AM   #18
beidle99's Avatar
For clutch bearings I have been using the same sets for gallons and gallons (upwards of 15 gallons or more) This process started by accident but it has worked for me. Here it goes...
supplies needed, 1 pint or quart of Marvel mystery oil, 2 sealable containers (I use old film canisters), motor spray.
I have three sets of clutch bell bearings. 1 set in the buggy (pair 1), 1 set in oil in my pit bin (pair 2) and one set in oil at home (pair 3).
After a day of racing, I take out the set that are in my buggy clean them with motor spray and put them in the container at home (pair 1 has now become pair 3). I then take the container thats in my parts bin and pull out the bearings let them drain on a towel for a little bit of time to get all the excess oil out so it doesn't foul my clutch (pair 2 has now become pair 1). These go in my clutch for the next race day. The pair that are at home then go into my tool bin. (pair 3 has now become pair 2). If you race every weekend, each pair of clutch bearings gets 2 weeks off and 1 week on. But in case of a failure you have a set that has been in oil for almost 2 weeks.
beidle99 is offline   Reply With Quote
Old 08-02-2011, 05:27 AM   #19
+ 1 on the TKO special steel clutch bearing. I've got nearly 2 gallons on mine and I have not touched them. The bell spins as freely if not better than when I first installed them. No grit or anything. I blew out the standard kit Agama bearing on the front of the clutch bell within 1 tank and thought f this. This can't be happening. Switched over to these TKO's and man they just work. No maintenance, nothing.
http://tkocompetitiondev.com/product...roducts_id=375
John. is offline   Reply With Quote
Old 08-02-2011, 06:14 AM   #20
Suspended
Trader Rating: 202 (96%+)
Originally Posted by 071crazy View Post
If they're 1.00 each, why would you risk running the same bearings for 2 gallons?
if its not broke dont fix it. the majority of poeple who have problems every race are the ones who tear their truck down everyday to replace parts that dont need to be replaced.
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 08-02-2011, 07:24 AM   #21
scwrod's Avatar
I would disagree here. I service and reuse bearings all the time.
I have had brand new bearings that had alot of drag. I removed the seals cleaned out the factory lube. Then relube(3-in1) resealed and they spun much better. I have been doing this for years. I will agree that if it is gritty after servicing then toss it. I must also mention I do not use $1 bearings. I have used Boca Bearings(Green Seal) for years and they have been excellent.
The only reason I started servicing bearings is I have alot of vehicles.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 08-02-2011, 10:07 AM   #22
Limywidget's Avatar
I have never seen this hold true. Its usually the ones that throw their vehicles in a vehicle and go from race to race with no maint that have the fits. I always find something that needs to be fixed as I go through my vehicle. So on race day I rarely dnf unless its something that I have done wrong from lack of experience/knowledge.
www.ROCCKracing.com
Bacon is meat candy without the fussy wrapper...
"Equations are the Devil's sentences." - Colbert
OODA loop: Observe-Overreact-Destroy-Apologize
Limywidget is offline   Reply With Quote
Old 08-02-2011, 10:09 AM   #23
Limywidget's Avatar
this last weekend I could spin my clutchbell and it would move freely. I pulled the bearings anyway and the rear clutch bearing puked all over the place. The race and everything fell out into the floor.
www.ROCCKracing.com
Old 08-02-2011, 10:20 AM   #24
I agree.. It's not that black and white of course, but for the most part, I do think people are constantly trying to fix things that aren't broken..
-TT MT4 G3
Old 08-02-2011, 10:20 AM   #25
Suspended
all depends i guess, ive seen it go both ways, guess ive been lucky
Old 08-02-2011, 12:28 PM   #26
Sorry, not sold on it. I'll keep spending $2.00 every 2-3 weeks.
TPJ International
071crazy is online now   Reply With Quote
Old 08-02-2011, 12:51 PM   #27
Suspended
its not the money that is a issue, i was simply stateing that the 1.00 bearing will last and are all you need
Old 08-02-2011, 01:39 PM   #28
j_blaze14's Avatar
Trader Rating: 34 (100%+)
5x10, 1 time oil and toss next clutch service, about 1 gallon or 1 race event. 8x13's i run until the seals get loose or they are not smooth after greasing, sometimes 2 gallons. my replace cycle starts before a main so i start my mains with new bearings and then run practice and warmup with the same bearings till my next main.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 08-02-2011, 02:04 PM   #29
Frank L's Avatar
Trader Rating: 148 (100%+)
Are you saying that you burn a whole gallon of fuel in 1 vehicle every race day??
Old 08-02-2011, 04:03 PM   #30
warnked's Avatar
$1 bearings ?! when it comes to bearings, you get what you pay for.
AE B4.1 Worlds, Losi XXX-T CR, Tamiya F104, Jammin x1x, HPI rs4 evo+
warnked is offline   Reply With Quote
