Old 08-01-2011, 11:56 AM   #1
Default Fuel Tank tips
I have a D8 fuel tank on my XB808, when the car turns upside down and if the tank is half empty the engine stalls almost immediately.
Then tank is not leaking. I have checked the clunk and it seems to work fine.
I have replaced the fuel line inside it with a softer one.
I have not used the original xray tank because there is no clunk on it, hence that means that after I turn the buggy upside down after a 10 seconds the engine will stall. Correct ?
Are there any tips on how to overcome this issue ?
Or are there any better tanks that fit on xb808?
mike80 is offline   Reply With Quote
Old 08-01-2011, 12:01 PM   #2
morgoth's Avatar
Don't hit the throttle lol. I run an mbx6 without clunk and my car nevers stall during a race while upside down. It does stall sometimes when I'm practicing and I'm endlessly waiting on marshall to flip me because I'm too lazy to go downstairs. Mine idles fine for about 20-30sec upside down without clunk.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 08-01-2011, 12:03 PM   #3
l3asher's Avatar
They have some good info in this thread.
my engine stops when the buggy is upside down
l3asher is offline   Reply With Quote
Old 08-01-2011, 12:12 PM   #4
Shall I use the original xray tank instead without clunk ?
will that be ok?
Old 08-01-2011, 12:34 PM   #5
morgoth's Avatar
will that be ok?
I should be OK. There are a lot cars out without clunk and they all idle fine upside down. Just don't rev the engine since you'll burn the fuel inside the fuel line. Just make sure you tune your engine good and it will long enough in a race. I about 30cm of fuel tubing in my car. From the tank to the front bodypost and then to the carb.
Old 08-01-2011, 01:32 PM   #6
stallen50's Avatar
Trader Rating: 30 (100%+)
i run d8 with the clunk and no problems how much tubing did you leave inside the tank? the clunk has to move freely. i had a problem with mine when i replaced my fuel tube i pushed too much line inside the tank and when the car flip over the clunk didnt move to the top. like it was supposed to do. thats my 2 cents
agama a8 usa edition
Arrow gtr.21, os speed
savox servos
thanks to my 2013 sponsors: vp-pro tires, hobbypro usa, beta tires, arrow racing, team terribles, boca bearings
stallen50 is offline   Reply With Quote
Old 08-01-2011, 01:33 PM   #7
stallen50's Avatar
Are you running the fuel tank mod?
savox servos
Old 08-01-2011, 07:47 PM   #8
xray2050's Avatar
Trader Rating: 14 (100%+)
Nothing wrong with the xray tank. Use it, you wont have any problems. If your engine sound changes as soon as you flip the car over, example; engine revs up, adjust the LSN. A properly tuned motor will idle upside down.
Pete Elphinstone
RC America, HUDY, XRAY, JACO, Performance Hobbies, WERKS RACING, www.speedzoneusa.com, Sweep Racing USA
xray2050 is offline   Reply With Quote
Old 08-01-2011, 08:57 PM   #9
TX_Punisher's Avatar
Explain, please.
XRAY XB9 & XT8 ☆ Airtronics M11X ☆ Novarossi Powered☆ Werks Fuels ☆ Hitec
TX_Punisher is offline   Reply With Quote
Old 08-02-2011, 05:54 AM   #10
Mike XRAY tank is fine. I've seen plenty of guys run the kit tank on their 808. Not having a clunk you should just run extra fuel line as morgoth said to prevent it stalling when its upside down. Adding an external fuel filter would also give a little more fuel in the line to help when it's upside down.
John. is offline   Reply With Quote
Old 08-02-2011, 10:15 AM   #11
I think this is the best solution!!!
Old 08-02-2011, 03:42 PM   #12
shesha's Avatar
Send a message via MSN to shesha
sounds to me that your low speed needle is not tuned right, check it again, and yes having a longer fuel line and fuel filter also helps, never once stalled being upside down with xb808 tank.
Your idle should be set right a 0.5 gap is usually in the ball park but different fuels different brands different plugs all have contributing factors to your idle setting.
Read up on the engine threads, plenty of info there.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Cutting out engine, intake and fuel tank holes in 1/8 body? jt415gz Painting, Designs, Graphics and Photography 10 01-25-2011 07:38 PM
Leaking fuel tank lid MattFL Nitro Off-Road 12 04-25-2010 08:20 PM
OMG Rust in Fuel Tank! Dragon Nitro On-Road 7 06-15-2005 08:55 PM
