Old 07-25-2011, 05:42 PM   #16
tc5 man's Avatar
i have raced on a track with loomy dry/wet dirt, and i found out that the i-beams soft work good. But i noticed on my rc8te truggy maybe its my setup, but it took a lot of rotateing from the rear away felt like it was to tight on the rear.
the jconcepts crosshairs soft work the best on loamy dirt, if you ask me at least i thought so the rear end has looser feel to it also.
i beams soft work good on dry /dusty /loose dirt from my exprience, the jc crosshairs soft are ok on that type of surface .
on what ( killerbud) said about the i-beams are spead to much, and there unstable i think that depends really on what kind of truggy you have, i think there pretty stable on my rc8te yea its not run as a nitro its electric so that could be why.
and also on the weight of the truggy in the wideness of it depends on how stable it will be reguardless.
tc5 man is online now   Reply With Quote
Old 07-25-2011, 06:28 PM   #17
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
if you have a stock pile of parts, proline bad lands are the way to go!!!! just get ready to traction roll ALOT!!!
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Old 07-25-2011, 10:51 PM   #18
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
I found City Blocks on the front, and Bowties on the rear of my Serpent truggy. This setup hooked up great, and still allowed the rear end to rotate around tight turns with ease. It tracked straight and accelerated hard when I punched it out of the turns, without the back end going all wanky. I've also tried City Blocks with Crime Fighters in the rear with favourable results.
I also find that the rounded shape of the Bowties in the rear of my truggy helps prevent traction rolling when I pitch it hard into the corners compared to the flat shape of tires ( like the City Block ) which seem to catch an edge when the track gets blown out.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 07-25-2011, 11:37 PM   #19
v6shooter's Avatar
aka crossbraces, They allways work for me in loamy type of tracks
Xray xb9 , alpha A852 with 2081 pipe, b4, dualsky xc550mj,thunder power 17.5, futaba,Radiopost ts-401
v6shooter is offline   Reply With Quote
A.E. HAS SOMETHING IN THE WORKS... tedstryker Electric Off-Road 3873 04-29-2011 06:47 AM
Looking for a track near Cleveland, TN JoeyTheRocket Tennessee-Kentucky Racing 9 08-19-2009 08:50 PM
MF1 advice for a newbie nf_ekt Electric Off-Road 10 01-04-2006 06:03 AM
Best Step Pin Tires??? SS LS1 Electric Off-Road 8 04-16-2004 01:47 PM
